Question about Frigidaire CWS3600AS Top Load Washer
Frigidaire Top Load Washer Won't Agitate FWS645GFS1
3 Year Old Frigidaire Top Loader. Agitator isn't working. Replaced Agitator and ran it without load in and it worked fine. Put a load through and it doesn't function - sort of tries lightly to work but not really. No other problem with the machine, no odd sounds, spin works, etc.
I am thinking that there is a problem with the drive belt slipping and not being able to turn the agitator mechinism in the transmission when under load. Otherwise it's obviously in the transmission itself.
Thanks, Jon
  • jjwitwer Sep 15, 2008
    The unit spins and I can hear the motor running when the agitator should be running. Would that indicate a good motor?
    Scholar:
  • 83 Answers
Sounds like something slipping or an actuator to the transmission not functioning fully if it cannot take a load. Not all machines use belts but rather direct transmission via gearing etc.
Something may be worn in the transmission.
Posted on Sep 15, 2008
  • Richard Florey Sep 17, 2008
    Jon,
    If it spins then the motor for that function seems fine.
    Sounds like the mechanism for the agitator.
    Sergeant:
    Champion:
  • 331 Answers
I guess you may be right
or maybe the motor
is not rotating with the ussuall speed pls inspect it..............
and ask for a technician .......
  • Varun Kumar
    Varun Kumar Sep 15, 2008
    if u hear the motor running
    the motor is fine
    i guess there must be some king of slip occuring could you try to reinstall the agitator?
  • Varun Kumar
    the motor is fine
Clothes wrapped around the agitator at end of cycle
Can you describe the problem more better? Does it still agitate properly? Have you checked the balance of the tub? I believe you have a bent agitator shaft.
Mar 13, 2014 | Frigidaire FWSB7800DS Top Load Washer
Frigidaire Fex831cs Top Load Stacked Washer won't agitate
I worked on one last week which was completely dead. Some wires were cut. Took a few pics: Laundry Center repair
Service manual
Jun 21, 2012 | Washing Machines
Frigidaire stackable model FEX831CS0 won't agitate or spin
Hi Kathy.
If the washer does not agitate and spin, then the most common problem is the belt: Washer Drive V-Belt (part 28 in diagram 1)
If you can manually advance to spin but the machine does not agitate, then parts that may need to be replaced are the agitator:
Agitator (part 11 in diag 1) or the agitator drive in the transmission:Agitator Drive (pt.2 diagram 2)
To replace the belt remove the assembly at front top of the washer held by two philips screws and clips. Here description of replacement procedure.
Here Diagram 1
Here Diagram 2
Regards.
Ginko
Nov 18, 2011 | Washing Machines
Whirlpool top loader model #LA9500XTNO won't agitate
the agitator dogs need replaced sounds like.4 little comma shape pieces underneath the top of agitator
Jan 15, 2010 | Washing Machines
Whirlpool top loader washer not agitating
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
I hope this helps you.
Vic
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
GE TOP LOADER DOES NOT AGITATE DURING WASH CYCLE BUT DOES SPIN DURING EXTRACTION
Remove the agitator and check the agitator splines also the agitator coupling on the shaft may be stripped.
Feb 21, 2009 | GE WBSR3140DW Top Load Washer
Kemore 90 Serieswashing machine fills and spins but won't agitate
Remove the agitator and see if the agitator shaft moves during agitate. If it moves then the agitator spline is worn or the agitator dogs are worn and the top half of the agitator will not work. If no results then the gearcase would have to be replaced
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washer wont agitate with med - large loads
Without knowing the age of your machine, your agitator "dogs" may be wearing or worn out. It should be fairly easy to check them out. You will need to figure out how to remove the agitator Usually the agitator will have a fabric softener dispenser or a cap on the top. Pull the dispenser/cap off the top of the agitator and you may see a screw holding the agitator in place. Once you lift the agitator out, the "dogs" should be visible. Most appliance stores should carry the dogs for your particular washing machine. I've added a couple of photos so you have an idea what to look for.
Black powder under the motor??? The motor uses carbon "brushes" to electrically make the motor move. Without going into motor theory, I would tell you that the black powder, in a small amount, is normal. The brushes can be replaced, and again, can be found at most major appliance dealers
Jan 11, 2008 | Amana ALW880WH Top Load Washer
Stinky Washer
We had the same problem with our front loader. (after only a year) We ran a load on "sanitary" setting with bleach. After that we leave the door open after EVERY load. That has fixed our problem
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Frigidaire CWS3600AS Top Load Washer Logo
229 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
