Question about Goodman Heating & Cooling
Blower motor on Janitrol heat pump does not blow at a high speed. There are no air flow restrictions.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
CHECK THE BLACK WIRE FROM THE FAN MOTOR TO THE CIRCUIT BOARD FOR LOOSE CONNECTION!.
Posted on Sep 15, 2008
2007 Buick Lucerne CXL: Cooled seats not working. LIghts come on, temperature adjusters work but the motors under the seats do not come on.
Air Circulation
When the heated/cool seat switch is pressed to initiate operation of the climate control seat (CCS) system, cabin air is drawn through the heated/cool ventilation module air filter, then directed through passages in the foam of the seat cushion and seat back to the seat's occupant. In order for the CCS system to operate to its optimum performance, it is crucial to have unrestricted air flow through the system. A dirty or restricted air filter, the blockage of an exhaust air duct, a misaligned heated/cool ventilation module, or incorrect foam installation of the seat cushion or seat back will all have negative effects on CCS operation.
Heated/Cool Ventilation Module
Each heated/cool seat has 2 ventilation modules, one located under the seat cushion and one located in the seat back. These modules are controlled by the climate control seat module (CCSM). Each ventilation module contains a thermo-electric device (TED), a temperature sensor, and a blower motor. The TED and temperature sensor are mounted downstream of the blower motor. Each TED consists of a circuit of positive and negative connections sandwiched between 2 ceramic plates. Each ceramic plate is equipped with copper fins for heat exchange. The air flowing past these fins is either directed as conditioned air into the seat cushion and seat back, or directed into the cabin as waste air.
A TED is essentially a solid state heat pump that is used to heat or cool the air supply to the seat cushion and seat back. When voltage is applied to a TED, one side releases energy as heat, while the opposite side absorbs energy and gets cold. When the polarity of the current flow to the TEDs is switched, the hot and cool sides of the TED reverse.
During the following climate control seat system description and operation, the TEDs, blower motors, and temperature sensors will be referenced independently even though they are all packaged together as a module.
Climate Control Seat (CCS) System
The CCS system consists of two heated/cool ventilation modules and one climate control seat module (CCSM) that controls both the driver and passenger heated/cool seats systems. The CCSM is mounted below the front passenger seat cushion. It receives power from both, battery positive voltage and ignition 3 voltage.
Once a CCS system is activated, cabin air is drawn through the seat blower motors and directed across the fins of each of the thermo-electric device (TED) located under the seat cushion and in the seat back. The air is either heated or cooled as it passes over the TEDs. This conditioned air is then directed through channels in the foam of the seat pad and through small holes in the seat cover to the occupant. Once the system is activated, the CCSM uses a set of algorithms to control the temperature of the selected heating or cooling modes.
Your best bet is to take your vehicle to a qualified repair shop an have it diagnosed .
DTC B19A4: Driver Seat Back Blower Speed Circuit High
DTC B19A8: Driver Seat Back Blower Speed Circuit Short to Ground
DTC B103D: Driver Blower Power Circuit
DTC B272E: Driver Seat Back Blower Circuit Open
DTC B19A3: Driver Seat Cushion Blower Speed Circuit High
DTC B19A7: Driver Seat Cushion Blower Speed Circuit Short to Ground
DTC B2729: Driver Seat Cushion Over Temperature
DTC B19A2: Passenger Seat Back Blower Speed Circuit High
DTC B19A6: Passenger Seat Back Blower Speed Circuit Short to Ground
DTC B111D: Passenger Blower Power Circuit
DTC B272F: Passenger Seat Back Blower Circuit Open
DTC B19A1: Passenger Seat Cushion Blower Speed Circuit High
DTC B19A5: Passenger Seat Cushion Blower Speed Circuit Short to Ground
DTC B272A: Passenger Seat Cushion Over Temperature
Driver and Passenger Heated/Cool Seats Inoperative
  1. Ignition OFF, disconnect the C1 harness connector at the CCSM.
  2. Test for less than 5 ohms between the ground circuit terminal M and ground.
  3. ?‡'
    If greater than the specified range, test the ground circuit for an open/high resistance.
  4. Verify that a test lamp illuminates between the B+ circuit terminal E and ground.
  5. ?‡'
    If the test lamp does not illuminate, test the B+ circuit for a short to ground or an open/high resistance.
  6. Disconnect the C2 harness connector at the CCSM.
  7. Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 1 and ground.
  8. ?‡'
    If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
  9. If all circuits test normal, replace the CCSM.
Sorry
Jul 10, 2016 | 2007 Buick Lucerne CXS Sedan
Weak blower motor
Check good voltage and ground for blower motor. Actuators under the dash may be restricting air flow? High speed doesn't usually use a resister.
Check for hvac trouble codes, in my part of the country, some of the national brand autostores will check codes for free, if there are any.
If you think problem with blower motor, itself, replace it. Sometimes, you can remove blower motor, use jumper wires for voltage and ground, using inline fuse, come off the battery, see if it blows like you think it should?
May 07, 2016 | 1999 Chevrolet Lumina
I have no heat or air blowing out of my vents. Any ideas?
still nothing,????
why do this backwards. ??
or not using simple diagnosis>?
so really you failed to state the beginning symptoms?
was it just just noise. or noise and no blow.
or the noise is gone,, but my fix broke the blower.
there will no heat not moving, if the blower is dead.
get heat , moving in non circ, mode.?
sure i bet you do an that is SOMETHING.
does the blower make sounds like a normal blower, then if no air flow
the dampers are bad.
blower silent? on all speeds, , do say so.
blower works only on high (sounds) ?
if the blower is running, surely you can hear it spin fast.
and there is no flow, the damper is bad or the blower fan blade set screw
is missing and or loose. did you check that screw first. before.
replacing the motor? id not ever skip that step.
we can not help you ,with no facts or symptoms but still nothing.
Sep 16, 2014 | 2006 Jeep Commander
Aircondition fan motor changed running ok but little air through vents
Does it still sound like its on high? If so you could have your vents blocked/restricted or your blower is not blowing on high speed. Usually a blower resistor if not blowing at max or not blowing at all speeds
Dec 03, 2009 | 2001 Lexus RX 300
Rheem gas furnace blower unit not working properly
look at circuit board and follow wires that come from fan motor, if this is a standard motor black is high and it will be going to a prong that says cool, red is low and it will go to heat, you will have a yellow and a blue that are "parked" remove red park it were the blue is and put blue on heat, if this is a variable speed motor you will have to set dip switches via your equipment manual
Sep 29, 2009 | Heating & Cooling
My coleman 3 ton heat pump blows very little air
Check the blower capacitor and blower speed, you probably have a 3 or 4 speed motor make sure it's on medium high or high speed.
If these are ok then shut the power off to the indoor unit and pull the blower housing out so you can see the blower wheel, make sure it's clean and very carefully spin the wheel to see if it spins freely keep hands away from wheel while it's spinning, if it doesn't then the bearings are bad and you need to replace the motor.
Apr 28, 2009 | Heating & Cooling
96 Jeep Grand Cherokee will not blow out hot air
It's possible you are not getting enough coolant flow to your heater core. Try pulling the hoses off the core, blowing it out with air compressor, fill with water and blow out again. Try this about five times and see what happens. Alot of times these cores will plug up or have restricted flow. They will blow warm at low speed but it won't flow enough hot coolant through to stay hot on high blower speed.
Feb 09, 2009 | 1997 Jeep Grand Cherokee
2002 saturn heater
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing.
Nov 23, 2008 | 2002 Saturn Sl
Heating & Cooling Logo
129 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
