Question about Maytag Neptune MDE5500AY Electric Dryer
Control panel not lighting up
Maytag Neptune Electric Dryer - Model # mce8000ayw
I'm not getting power to the control panel...I checked to make sure that it's getting 110 on both sides of the outlet. I do get lights in the upper cabinet but that's all I'm getting. Is there possibly a fuse or reset switch anywhere on the dryer? I checked all through the owner's manual and couldn't find this problem listed under troubleshooting. I appreciate any input.
Thank you! Rick Kuelker
  • kelknstl Sep 15, 2008
    I tried unplugging it for about 30 mins. and plugging it back in but that didn't do the trick. My wife said she used it Saturday and it worked fine. We a little bit of water in the basement Saturday night from a heavy rain from but I don't think enough to be a problem. I'll leave the dryer uplugged until I get home from work this evening and try again.
    Sergeant:
    Champion:
  • 214 Answers
Is the drum light on while the door is closed?? look on the tech sheet found in the lower front panel for a wiring diagram memory servers me there is a thermal fuse chances are this is bad.
Posted on Sep 15, 2008
    Sergeant:
    Champion:
  • 331 Answers
You will have to heck the back panel of your dryer
there will be a digram
identify the switch otr the fuse and replace the same
  • 13,433 Answers
Hey, there should be a fuse, 20amps possibly, in the back, there may be a metal cover with a screw ontop to keep it closed. Look in the back I have seen a few pictures, but im perfectly sure where it is in your model.
  • Ekse Sep 15, 2008
    but im not sure where it is in your model I will have to look into that.
    Master:
  • 726 Answers
There is a fuse inside the machine but try to unplug it for 15 mins to reset and see what happens
What causes maytag neptune dryer has pf error? My dryer worked in air fluff but not sensor or timer mode. Now it will not work at all. the lights on the control panel just blink . What could be the cause..
Pf shows a power failure hols the stop clear button and it should work again.As for your other problems I will more details such as a model number Gas or Electric dryer and example of the problem in detail
Aug 05, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Why does my Neptune moder number mce8000ayw dryer not tumble?
If the motor runs, but the drum doesn't rotate, check the belt, part # 341241. It's probably broken and off of the drum.
May 14, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune
Make sure your light control is turned on. Either turn odometer pin or there is a control left of steering wheel that controls the light level
May 11, 2012 | Maytag Neptune MDE5500AY Electric Dryer
I need the diagram that comes with the dryer. Maytag Netune Model MCE8000AYW
depending on the serise which is the first two numbers of the serial number here is the diagram http://lookup.bellparts.com/diagramenlarge/2/0/561302/91934
Hope this helps
Jun 18, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Model MCE8000AYW, Lower dryer section - no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 14, 2010 | Maytag Neptune MCE8000AY Electric Dryer
I have a maytag dryer model number is mce8000ay
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Dec 23, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Where's the power source...
He most likely want you to check the power at the wall plug...Red to white 120v black to white 120v and Red to black 240v... if you have it at the wall check the other end of the pig tail .. make sure a wire is not burn off at the terminal block...
Oct 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Electric Dryer - Control panel doesn't light unless door is open
the power connects for the 240 volts to the outside screws on the terminal block the center connector is the nutral connection
Jun 09, 2008 | Maytag Neptune MDE6800 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
157 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
