Question about Zanussi FJS1225W Front Load Washer
Plumbing cant find how to plumb the mcahine in
  • 3 Answers
It depends if you have the connections already there. If not then you can make a tee branch from the hot and cold pipes running to your kitchen sink. Then solder 2 15mm branch pipes. this will now be your hot and cold feeds to your machine. At the end of the branches attatch a washing machine valve (red for hot, blue for cold. You can now attach the hoses from the machine to the valves you have just fitted. Really easy
Posted on Feb 17, 2009
Where can I get the tools for plumbing?
Tools are the ornaments of plumbing professionals. Without the tools, the plumber is not able to do his work. For doing plumbing at home on your own, you should have right tools for it. For proper tools, you should have an idea about tools, and you can get a best options on Arvada Plumber
Mar 21, 2017 | Plumbing
Tip
Home Plumbing Tips
Plumbing is a learned skill, and often mistakes are made because the home handyman does not have the knowledge of the proper tools, compounds or pipe for the job. All plumbing systems get clogs eventually and a lot of time can be saved on a plumbing job if you follow a few simple rules. You can fix the plumbing problem by yourself if you have the right tools, know the technique, and you are prepared to do it. The tools aren’t all that expensive, and sometimes can be rented, but if after a few attempts you can’t get the clog loose, call a San Diego professional plumber.
on Aug 19, 2010 | Plumbing
What are the uses of plumbing?
Plumbing nowadays is specially used for small quantity water consuming in society building or in factory main supply from where the distribution of water is done via pipe line system called as plumbing. It is also said that, plumbing is the collection of connected pipes, it can be done in commercial as well as residential areas. The main goal of Assistance Plombier 77 is to reduce the wastage of water and to keep the environment clean and healthy.
Nov 12, 2014 | Watches
Anyone can suggest me a good plumber ?
Yes I know one company, which can deals in Commercial and Residential plumbing. It's been providing their services for ten years'. For more information you can check this site. http://www.ps2i.biz/
Jun 05, 2013 | Mountain Plumbing Home
Which site is best for finding a professional plumbing services?
You can ask for emergency plumbing services at anytime from Emergency Plumber Arvanda which is one of the best site that provides you with the professional plumbers that can treat any problems related to plumbing right from simple to a complex one. And they try to come to your place as soon as you make them a call regarding your problem.
Apr 06, 2013 | Mountain Plumbing Water Heaters
Plumbing diagram required
maybe this will help:
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pnghttp://www.bing.com/images/search?q=Bathroom+Plumbing+Diagram&view=detail&id=3A7A68688CAEB247D8ACC1DE25AD2033E5260433&first=1&FORM=IDFRIR&qpvt=plumbing+diagram
Apr 28, 2011 | Moen Home
Trying to recharge my A/C in chevy tahoe 2000 cant find the valve where i need to attach to.
The low pressure side port is located somewhere on the 'thicker' plumbing vs. the 'thinner' plumbing coming off of the compressor.
The pressure should be 25psi to 45 psi when the compressor is running.
You can't connect the low pressure hose with a can of r134a on the wrong side (high side vs. low side) because the ports are a different diameter (size).
It may be on the accumulator as well, the canister looking part of the a/c plumbing.
Aug 19, 2010 | 2000 Chevrolet Tahoe
No instructions
Open the cardboard dust cover on the rear of the ice box and connect your water line to the water valve. Here is a pic: a8e6c7c.jpg
Jan 31, 2009 | Admiral 26 cu. ft. Side-By-Side...
Zanussi FJS1225W Front Load Washer Logo
67 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
