Turn on at power button no rotating "hour-glass" ; screen becomes blue then displays vertical multi-coloured stripes over whole screen. Sound From tele program. No reaction to remote cntl
  • irvingballsn Sep 15, 2008
    see previous message & yr ssuggestion have connected different television set to aeriel &pwer supply. This functions OK. Plse advise.
    Master:
  • 726 Answers
There will be a fault inside the tv like the convergence board you no doubt will have to get a electrician to advise u further or fix it
Posted on Sep 15, 2008
    Sergeant:
    Champion:
  • 331 Answers
There is a problem with the connection
asthe screen becomes blue it mean that there is nothing to project
maybe the connecter is faulty
  • Varun Kumar
    Varun Kumar Sep 15, 2008
    could you tell me about the connecions which you have made??????????
  • Varun Kumar
Vertical rainbow stripes on my GB color
I would say that the screen is causing the lines in a gameboy colour the lines are not the same like it would be in an orginal gameboy the one with the four batteries. Lines in gameboy color are the screen issues then the whole screen would have to be replaced on the GBC then.
May 18, 2013 | Nintendo Game Boy Color Console
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Sep 10, 2009 | Philips 42 in. Plasma TV
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Blank Screen
Check the cable to the back of the LCD and also where the cable connects to the motherboard on your laptop. These can come loose over time from the lid being opened and closed and will cause the fault you describe.
If the cable has moved out of the back of the panel itself, then apply a small amount of tape to hold it in place once pushed back in where it should be.
CAUTION NOTE:
These screens are fragile. Take extreme care when inside.
Mar 27, 2008 | Dell UltraSharp 1905FP 19" LCD Monitor
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Plasma Problem
It could be the Logic board or/and one of the Logic Scan board failure. Parts availability depends on maker and may cost any where between $250 - $500. Labour depends on shop. Hope that'll help you. Good luck.
Jan 26, 2008 | Televison & Video
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
