I use MS Office Word 2003 mail merge to produce a document which is a page of address labels. I put the sheet of labels in the bypass tray and set the properties to select that, BUT the printer just prints on A4 paper from the standard tray. Normal word documents print correctly from the bypass tray, so I'm guessing it's something to do with mail merge, but I can't work out what.
Any suggestions, please?
SOURCE: Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
SOURCE: Printing documents with wide margins on letter paper
Did you try to reduce the document down so it would fit a standered size paper???
SOURCE: MX2700N printer keeps giving A4 paper error.
Go to system setting, under printer setting there's a menu to forced output print or A4/Letter changing, if you can not find it try the key operator program/ admin mode ( default password for admin is admin )
SOURCE: Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
