Question about Hotpoint Dryers
Hotpoint ts 11 tumble dryer
Cant remove side panels to renew belt
5 Suggested Answers
  • 9 Answers
SOURCE: broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Posted on Dec 06, 2007
SOURCE: Replacing the Drive Belt
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Posted on Feb 03, 2008
TAGTEL
  • 16 Answers
SOURCE: TUMBLE DRYER DOES NOT GET HOT
Hi, - The first thing to do is UNPLUG THE DRYER! Then remove the heater cover situated on the back panel. It is the curvey shaped panel.
Remove all the screws and the panel may be slightly stuck - just prise it off.
Next - there are 2 small screws holding the heater and thermostats assy onto the back panel. - Remove these to free the assy from the back panel. Be careful not to touch the elements as they break easily.
The problem is probably the Thermostats.
The one on the left is the Overheat Thermostat - You will notice a small hole in the centre of the thermostat. Take a Pin and push it firmly into the hole and you may hear the Stat "click". That has re-set the stat.
Re-assemble the Dryer being careful with the elements.
Now - Why has it tripped? If it has overheated it is because of one or all of the following.
1. The Condenser unit is getting blocked - Remove and clean under running water like a hosepipe or tap.
2. The door filter is not being cleaned
3. Sometimes opening the door to check if the clothes are dry and then not allowing the dryer to cool down can cause the problem. Always allow it to go through the cool down process.
Hope this helps. The Heater and the Thermostats are available as Spares - Terry
Posted on Mar 15, 2008
wmsfarris
  • 22 Answers
SOURCE: hotpoint condenser tumble dryer model tdc30p belt replacement
You will have to unplug the dryer and remove the front panel with the door, mark and remove the wires to the door switch, then there should be two screws on the inside which you will need to remove then tilt the panel out and lift to disengage the tabs connecting it to the main cabinet. Then you should be able to remove the old belt, carefully lift the drum and slide the new belt under it. Then this is where you will need to be a contortionist and take care as there are many sharp edges under there. Locate the motor and tensioner pulley, place the belt around the tensioner and while pushing back against the spring on the tensioner hook the belt to the motor pulley, then move belt on drum so it is aligned with lower pulleys. Turn the drum by hand a couple of times to make sure everything works.
Posted on Apr 04, 2009
vickygomar
  • 460 Answers
SOURCE: How to remove front panel of dryer
Be sure to unplug the machine from the mains,
1.-Remove the top cover of the machine, very straight forward.
2.-Unclip the universal coupling from the main timer to the back of the knob.
3.- The whole knob assembly is held in place by a backing plate.
4.- There are 2 clips at the top of this backing plate raise them and the backing plate and knob can be pulled out.
5.- there is a plastic clips but be careful not to break it.
Your ffeed back and ratting are so important for me. thank you
Was this helpful?
The knob breaks when it has been turned in the wrong direction several times. It's a safety device so as not to damage the main timer.
Posted on May 21, 2009
The wiring to my hotpoint tumble dryer
You would have had to disassemble the dryer to replace the belt, so the video was correct. The door switch assembly wiring at the front of the dryer mates with a matching connector which you would have separated for cabinet removal. Don't know why you messed with control panel wiring for belt replacement but you can go to www.repairclinic.com and enter tcym 750c to see a list of common replacement parts and maybe a video showing disassembly of a generic Hotpoint dryer. You might be able to get an answer to your wiring question.
Aug 10, 2016 | Hotpoint Dryers
Hotpoint TVF760 Aquarius + change belt
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Aug 06, 2013 | Dryers
Cant get top off dryer vtd00
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Need to replace belt on vtd20g hotpoint tumble dryer
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
May 10, 2012 | Dryers
Need to take apart a hotpoint tumble dryer vtd00t
Sep 21, 2010 | Dryers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
Can't work out how to fit new belt to my tumble dryer it's a hotpoint aqurius dryer duluxe TL22.
You need to remove the rear panel the top console panel,,and then remove the whole cabinet to gain access to the drum and belt.
Then you need to release the front panel at the top to enable you to fit the belt.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
I need the procedures on how to change the drive belt on my Hotpoint VTD00G Tumble dryer. I've opened the top & front covers, placed the belt round the drum but I couldn't stretch the belt over the...
Apr 06, 2008 | Dryers
TS 12 Reversible electric dryer
easy !! remove the front door section complete ..
remove timerknob. + screw unclip the whole panel plastic.
remove 4 screws just under the plastic panel and then 4 screws on the bottom or front pannel. leave the screws at either side ON. you can then change belt/motor/pulleys. hope this helps.
Andy...
Sep 05, 2007 | Hotpoint TS13 Electric Portable Dryer
Dryers Logo
135 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
