Question about Cell Phones
Nokia 6120 water damage
my 6120 recently went through a wash cycle in our machine! i took it carefully apart as much as i could, then dried everything and left it on a radiator to dry further. once dry i put it back together and was amazed to find that it swithe on and worked fine. the only visible damge was a sort of watermark on the screen (lcd? led?).
unfortunately a day later it stopped working completely and now won't switch on.
i wonder if there was still some water in there and something to do with power is damaged?
can i fix it?
i wondered about trying to find another faulty one on ebay which will at least power up.
any help advice would be much appreciated.
  • Anonymous Oct 22, 2008
    I dropped my nokia 6120 into a glass of water, it was out of there in like 2 seconds though and i dried it up as much as possible. its working fine except for probably the most important part maybe.... i cant hear someone when they ring me. but they can hear me.
    any ideas on how to fix this?
    Top Expert:
  • Cell Phones Master
  • 79,094 Answers
You can try taking out the battery and putting the phone in a bag of Rice, the Rice is a drying agent, it will take 2-3 days, if the phone works you are good, if not you will need to replace it. The rule here of course is water and electronics do not make a happy pair.
Posted on Mar 30, 2017
techman
  • 3130 Answers
SOURCE: Water Damage!
its probably behond repair as Im not sure what you paid for that model but there sell here in the states for 79.95 US. I kind guessed you were not in the US as you said loo!!(he he} just a luck guess I guess/?
Posted on May 01, 2006
SOURCE: razr v3 water damage lcd
Hi there. There IS hope if you do get your phone submerged in water.
The most important thing you can do when your phone gets wet is to TURN IT OFF AND TAKE OUT THE BATTERY. Don't even try to turn it back on and "just check it" until you try to clean it out or let it air dry for several days. I didn't follow this exactly, but I got lucky, you might not if you wait too long.
I just had a phone mishap with a bottle of iced tea (wet and sticky, not a good combo), and thought my phone was completely shot, especially because it was on at the time it got wet. You could see the tea swooshing around beneath the front LCD panel, neither screen would turn on, it just made a steady high-pitched tone, then stopped, although the keypad was still backlit. I tried several times during that day to turn it on, but it wouldn't work. Since I like to tinker, I decided to take it apart, if it was supposedly a gonner anyway.
Google "repairing wet razr v3" and similar search terms. Various sites recommended taking out all the pieces, wiping them down with 90% alcohol (available at any drugstore or Target, etc), letting them airdry or using a compressed air can (or hair dryer on LOW heat setting). You need a special set of screwdrivers called Torx, I found one at Lowes for $6 that had interchangeable sizes of screw bits. Other postings on other sites mentioned either Torx sizes #3, 4, or 5 as the right one, but I had to use different sizes of the bits for various screws, so get a set and not just one size.
Don't be afraid of being just a little rough if you have to, to pry some of the parts off. The electronics/wire connectors between various pieces pop right off, but you will need a very small flat head screwdriver or some tweezers for some things, for example, prying off the outer cover, LCD covers, or lifting off the plastic glued-on backing underneath where the battery goes (you need to lift this off so that you can reach the metal brackets holding the keypad in place). I would suggest taking pictures of the phone at various stages of disassembly, so that you can remember where all the little bits go when you put it back together.
Other postings also talk about there being these little moisture sensing pads on various parts of the phone, that turn red when there's heavy moisture (which is a way that phone companies can tell if your phone is really defective, or if you got it wet, which your warranty might not cover). As an FYI, there are additional pads that you don't see until you take it apart. There was one underneath the keypad, and one underneath the inside LCD. The screws also had some sort of color coding on them on the threads, 2 were red and 2 were green. I don't know if this was b/c of moisture, or a way to tell if the phone had been opened, or they're just made that way for manufacturing.
I put my phone back together, replaced the battery, turned it on, and..... it turned on!!! I called my husband on the land line in another room, I heard him, he heard me. It's worked fine ever since, I can still take pics, all my contacts and text messages were still saved on the phone (whew!).
When I first turned it on, the battery had run down from an almost full charge to one bar, but it recharged fine, although I think it takes longer to do so now. It also seems a little more sensitive to movement, but that is when I'm charging it as well (if I'm charging it while it's on, 2 times it suddenly turned off), although it was acting funny when the charger giggled in the before it got wet, so it's hard to tell if that's a new problem or not. I will probably get a replacement battery for it--$10 on eBay is a lot cheaper than $200-400 for a new phone!
Since most folks will tell you that you now have a lovely new paperweight, and if you don't want to send it to an expensive repair shop, and your warranty doesn't cover it anymore, you might as well try to fix it yourself. The worst that can happen is that it still won't work!
Posted on Apr 13, 2008
Bogdan
  • 198 Answers
SOURCE: water damaged n81 8gb
Hello play gal
Nokia phones of this complexity use at least 3 layer circuit board in order to fit all of those chips and other components in a small casing. When they get in contact with water they can retain it for a long period of time underneath the pins and those black chips. Also, the type of water involved may change way in wich the problem must be treated. Salt water is by far the most dangerous (because aftel the water evaporates the salt cristals remain and may still conduct electricity and form short circuits over the board) followed by water contaminated with foreign particles or other liquids. Normal water will not cause these problems but it can short circuit various components causing damage to the board.
In your situation, i would recomand that you dissasemble the phone, remove the display from the board and wash the board with propionic alcohol (or izopropilic alcohol). This helps by cleaning various foreigh materials or substances contained within the water that had contact with your phone. Let the phone to dry for about 1 day before you try to reasemble it. Don't force it to dry faster, let it in a sunny place to dry on it's own. In any case, never wash the display with this alcohol or anything else as this could affect it's quality or even destroy it. You may get propionic alcohool from electronic stores, radio shacks or service centers willing to sell it.
In case you dropped it in salt water you will need a lot of alcohol because you must place the motherboard in it for about 3-4 hours.
You may also try to simply power on the phone after 2 days (after the incident) to see if it works. Of course connect the battery back to it only after these 2 days.
You've asked if the phone is damaged now? That depends mostly on 2 factors.
How long did the phone stayed in the water and how long did it remain with it's battery connected? The shorter, the better.
What type of water was involved? salt water or sugar flavored or other things are bad.
Posted on Jun 17, 2008
Remag1234
  • 387 Answers
SOURCE: nokia 6300 water damage screen still not working
Screen is probably fried and needs to be replaced.
Not covered by warranty or insurance. Cheaper to buy a new phone.
Posted on May 17, 2009
MobilityMan
  • 129 Answers
SOURCE: Water Damage T mobile G 1
Make sure that you take the battery and SIM out immediately. Find some desiccant and put it in the desiccant overnight.
Here are some other tips:
http://yourmonstersofmobile.com/how_to_for_cell_phones/dropped_your_cell_phone_in_water_this_might_help.html
Posted on Aug 23, 2009
Why is clean water collecting in the drum of my washing machine afer a cycle?
Replace the inlet solenoids. They are where the hoses attach to at top back of machine. Dead easy replacement. Couple of screws and a tubing clamp
Nov 01, 2014 | Bosch Washing Machines
Whirlpool Ultimate Care II is not draing properly and water is flooding out during spin cycle.
remove the hose up where it connects to the tub and see if there isn't anything stuck there,you could still have something stuck between the tubs and it usually will end up here or you could have a damaged pump from the piece of towel you pulled out of it or there's another piece still up in between the tubs and hopefully you'll find it at the hole where the drain hose is.
Jan 22, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine stops on spin cycle
You need a new drain pump.
May 04, 2009 | Washing Machines
Whirlpool Washer LSQ9645KQ0
The washer has the sound both times but not all the time. I THINK we found all the pieces but now that you mentioned it, perhaps not. Are you thinking there may be a piece lodged somewhere and making that noise?
di_marie60
Aug 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Nokia 6300 washed out
Unfortunately no....depending on the water damage that had occured. It would have been quite lucky if the phone actually worked. and if it did, other aspcts of the device may work now but fail later. No one part can be identified for repair because water can get into EVERY component. Making repar an expensive option. Replacement is the only recommendation
May 09, 2008 | Nokia 6300 Cellular Phone
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Dryer not wrking - letting in water
Does the water come in all the time? If so turn off each supply line faucet to identify which line is leaking and take that valve inside the washer apart and clean it out, if not completely replace that module. Let me know more about what exactly is going on.
Jan 17, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing machine
there could be several causes for this. he timer could be faulty and is calling for water in all cycles or you might have a bad pressure switch, which controls the water flow.
Aug 27, 2007 | Washing Machines
Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Oct 16, 2006 | Candy DQW150 Front Load Washer / Dryer
Cell Phones Logo
767 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
