SOURCE: craftsman leaf blower, primer bulb will not return, won't start
It sound like the primer bulb does not retract by itself due to aging problem.
SOURCE: 32 cc blower not starting
your problem is inside the carburator.there is a small screen inside that needs to be cleaned out.take the single screw from one side of carb.there is a small screen in side.carefully take an air hose and blow it out.do not blow to hard or the screen will blow out.once it's clean the unit will start right up.hope this helped,let me know.................................
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
SOURCE: need manual for craftsman blower/vac model 358
if you googel searsparts open that link then put in your model number and look for the link that says need a manual for this clik on it and you can get it hope this helps you
SOURCE: 2006 25cc 2 cycle craftsman leaf blower
The smaller line that has the fuel filer on it in the tank goes to the stem on the lower part. The larger line that just terminates shortly inside tank goes to the stem on the top of the carb with the bulb.
