USB I CANNOT FINE MY SLAVE HDD. CANNOT LOCATE THE SPECIFIC DRIVER.
  • 2 more comments
  • Anonymous Nov 11, 2008
    my pc WinXP SP2 Cannot Locate/read the Zynet HD-D5-U2 externl HD 3.5"...
  • Anonymous Dec 29, 2008
    where can I get the drivers
  • caracas541 Jan 06, 2009
    Vista Driver ?
  • Slam63 Jan 31, 2009
    Where's a driver that will work with Server 2003?
Usb dont work.please guide me
Posted on Sep 16, 2008
Computer doesnt pick up a usb
Remove the HDD from the enclosure and slave it inside your PC...if it reads it will be the enclosure is faulty. If still no read is faulty HDD.
Oct 16, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
I have a dx4720-03 and it will not boot up. The blue light behind the power button pulses slow. Could the mother board and or the CPU be the problem?
The motherboard could be the problem. However, you should first check that the master HDD to check if it is corrupted. You can check by either taking the HDD out of the computer and putting it in another computer as a slave HDD (it must be set as a slave drive because the HDD would not work as a master in another computer because the operating system has been configured to run on that one specific computer), you would need to change the drive from a master to a slave by changing the jumper pin found on the one side of the HDD, there should be a diagram on the top of the HDD which will show you how to change the drive from a master to a slave. Then just check that all of the data is on the drive. If it is then you know that the motherboard or the cpu is faulty.
The other thing you could do is if you have another HDD you can swap it out and test if it is working.
Hope this was helpful. Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Regards,
BearWeb
Aug 11, 2010 | Gateway DX4720-03 PC Desktop
Slave is ok but master freezes...
you can install even if it is a slave disk. also you can try setting the jumpers to master mode, check the sides of the hdd, it has a jumper setting and set it to master, using the shorting pin, just plug it out and connect it to the right setting
Jun 03, 2010 | Seagate Notebook Hard Drives: 40GB...
Laptop 2nd HDD(Slave) running max 20mb/s
Why not install a new 2.5" hdd in your laptop caddy.I replaced my 40gb with a 160gb, works fine and the data tranfer speed is better than a slave configuration. The average speed of around 40mb/sec Is because of the smaller platter, the amount of cache, the firmware installed and so on.
Apr 09, 2010 | Fujitsu Computers & Internet
I have intel DG31PR mother board and samsung SATA HDD and i installed windowsXP. Actually it was working fine for the last two months. But now the BIOS does not detect the HDD.
If the HDD isn't detected, this means either the HDD has failed or the disk controller has failed.
Most likely the HDD has failed, remove the drive and test it in another computer as a slave drive, if the other computer can see the drive and the files then the drive is OK and the fault is the motherboard/controller.
Alternately you can also test the HDD with a USB hard drive adapter and connect it to a working computer's USB port, if the computer sees it as an external drive and the files then the HDD is OK.
May 02, 2009 | Computers & Internet
Only one drive showing out of two
Hi the cable ribbon is color coded. the blue should be connected to motherboard and the gray is a slave and the black is master. Check if you have this connected properly. If you got a Cable ribbon not color coded. The cable ribbon from motherboard connector about a 12 inches long from middle slave connector and 6 inches to the master connector. If this is not connected properly and HDD is not assign slave and master most likely the OS can not detect the HDD. The other way to check is to access your bios setup if the slave and master HDD is detect. Your PC have a capability of plug and play if you connect the hardware right and load the driver. Hope this info will help you to solve the problem.
HH
Apr 20, 2009 | ASUS (M2NGREEN) Motherboard
Western Digital 80gb HDD Fails when installing OS
Try changing the jumper settings to make it the Master instead of the slave drive
Mar 23, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
