Question about Microwave Ovens
I have a EM-G653 model. The front pannel is not working sometimes. And the screen display: dEF kg, all the keys are not reacting, but the Stop/Cancel makes beep, beep when I pressed. But after a while, it works again. All of a sudden, the problem came back.....
  • jilly666 Sep 15, 2008
    yes i have a guess what sanyo and it is doing eactley the same as yours.seems it is quite dangerous to work with microwaves i you are not a proff so bit worried about having alook inside to see if its just a dodgy wire or something . if i have any joy fixing will advise you
  • Microwave Ovens Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Otherwise, it sounds like your "defrost" key on the keypad may be shorting.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
In the UK, you can find Sanyo support, parts and authorized servicers here.
Posted on Sep 16, 2008
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Dacor DM02420S Micrwave Display Screen - Can't see anything
can you see any thing like a circuit in that pannel.check for the soldering joints in that pannel.
Oct 12, 2008 | Dacor DCM24 Convection/Microwave Oven
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
Feb 03, 2012 | Panasonic Microwave Ovens
What doesl f2 mean on the display
The "F2" on a microwave can mean that the touch pad has a problem. Once I saw that message on a stove. The technician told me to press the "stop/cancel" button two times to reset the electronics. That fixed it. The electronics inside the microwave are usually timers and they adjust the strength of the microwaves for cooking. The best thing to do if the stop/cancel trick does not work, is to look at the owner's manual. If there is nothing there referring to that code, then copy the model number from the microwave (usually inside the door panel or sometimes at the back of the unit) and go to the manufacturer's website. Look for support, enter the required information and find out what the code really means.
Many times, it is better to let a professional take care of a repair on a microwave. If you leave something loose or not properly installed, you could endanger your health with microwaves hitting you improperly. Always be careful when working with this type of equipment.
Jul 16, 2011 | Microwave Ovens
My SANYO EM-D9550 display as stop working
You could have a failed keypad or control panel assembly, You can try the hard reeset the previous tech mentioned or you can try re-seating the ribbon cable on the control board. sometime thet get dirty not allowing them to work.
Nov 21, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Toaster Combe
The button may be stuck... try cleaning the display really well.
Oct 26, 2008 | Microwave Ovens
Nothin works on my key pad
Here are lock / unlock schemes for three recent Sanyo models:
- Press and hold Stop/Cancel for 3 seconds
- Press and hold Stop/Reset for 3 seconds or so
- Press Stop/Clear five times
Hopefully one of those will work.
If none of these work for you, contact Sanyo Service Customer Service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
Set the clock Sanyo EM-V860
You can request the manual in PDF form here: http://www.sanyo.com.au/aim.aspx
Mar 05, 2007 | Sanyo EM-S9515W Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
