Question about Epson Stylus Color 460 InkJet Printer
Seem unable to get my ink cartridge holder in middle position to insert new cartridge. have tried 2 TR27 copy cartridges from ABITECH Nottingham but both made the error light flash ! Printer id EPSON STYLUS PHOTO 810. I am now stuck with a new unusable colour cartridge fitted and I cant remove it. Any ideas please ?
  • Anonymous Mar 09, 2009
    i cannot change my cartriges i downloaded the ssc utility service but i cannot get in to the cartidge exchange
  • 353 Answers
I cannot remember if the Status Monitor (SM) of the 810 has a "change cartridge" facility, but it's easy to check. Right click the printer icon in the bottom right-hand corner of the screen and select printer settings. Then click the maintenance tab - is "change cartridge" one of the options? If so, use it. If it isn't you can download the SSC utility from
http://www.ssclg.com/epsone.shtml
and use this to move the cartridge to the cartridge change position - don't forget to use it to do an ink charge cycle after you have replaced the cartridge.
There is also the "generic" approach. Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move (gently!) by hand to the cartridge change position. The snag here is there is no inherent means of running an ink charge cycle - do a couple of head clean cycles instead.
Posted on Feb 01, 2009
I don't know how to load the ink into the printer of the iP 1600 Canon pixma
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Apr 25, 2011 | Office Equipment & Supplies
How do I change the ink cartridges?
Step 1:Purchase an ink cartridge made specifically for your printer. Step 2:Turn on your printer and raise the lid or press the cartridge changing button. Step 3:Wait for the cartridge carrier to slide out. Step 4:Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Step 5:Carefully remove the tape from the ink opening on the bottom of new cartridge. Step 6:Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. Step 7:Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. Step 8:If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge. Step 9:Close printer cover.
Jun 13, 2010 | Epson Stylus C86 InkJet Printer
HOW DO I CHANGE MY INK CARTRIDGE?
  1. Step 1 Purchase an ink cartridge made specifically for your printer.
  2. Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
  3. Step 3 Wait for the cartridge carrier to slide out.
  4. Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epsonmag-glass_10x10.gif printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  5. Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
  6. Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  7. Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  8. Step 8 If you have an Epson printermag-glass_10x10.gif, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  9. Step 9 Close printer cover.
Thanks
Apr 24, 2010 | Epson RX620 All-In-One InkJet Photo...
How do i change ink cartridge
While cartridge installation varies somewhat between brands and models, these general instructions apply to most major brands:
  • Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
  • Step 3 Wait for the cartridge carrier to slide out.
  • Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • Step 8 If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Step 9 Close printer cover.
  • Apr 21, 2010 | Epson Stylus CX6000 All-In-One InkJet...
    Unable to install cartridge
    Hello my friend, regarding on your problem in installing your cartridge you can see it inside in your printer. Open the printer cover then wait for the cartridge holder to stop swinging and stay in the middle then pull out the two platic attach to the cartridge holder. The plastic u pull out are the ink cartridge and then insert new ink cartridge then insert it again in the cartridge holder the close the printer cover and then you can print and used the printer. Don't forget to turn on first your printer before removing the cartridge.
    Jun 16, 2009 | HP DeskJet F4280 All In One Printer InkJet
    Shows black ink empty after new cartridge inserted
    Replacing the cartridge should resolve this problem: Follow these steps to replace the cartridge:
    Installing / Replacing the BJ Cartridge Follow this procedure to replace the BJ cartridge:
    1. Make sure the MultiPASS is plugged in.
    2. Open the document tray.
    3. Lift the document guides to open the ADF (Automatic Document Feeder).
    If the ADF (Automatic Document Feeder) does not open easily, slide the document guides outward and then open the ADF (Automatic Document Feeder).
    Or slide the Document Feed Lever to either the automatic or manual setting.
    4. Pressthingtopress.gif. If installing the BJ Cartridge for the first time, skip to step 6.
    Caution: Do not try to manually move or stop the cartridge holder since this may damage the unit. Do not touch the components shown or any metal parts since this may adversely affect operation of the unit and/or affect print quality.
    The MultiPASS has an automatic protection feature that helps keep it from overheating. If the cartridge holder does not move, unplug the MultiPASS and let it cool for several minutes. Then plug it in again.
    Press thingtopress.gifto move the cartridge holder.
    5. Raise the blue cartridge lock lever on the cartridge holder and remove the BJ cartridge.
    Caution: Discard the old BJ cartridge immediately according to the local laws and regulations for disposal of consumables.You may want to place it in a plastic bag to keep any residual ink from spilling. Spilled ink can stain any surface; protect yourself and your work area. If removing a BJ cartridge to use one of the optional BJ cartridges, be sure to store the BJ cartridge in the container provided with your MultiPASS. Otherwise the ink will dry and affect print quality.
    container.gif 6. Remove the new BJ cartridge from its package, then remove the orange protective cap (1) and tape (2).
    Caution: Discard the cap and tape. Never attempt to reattach them to the BJ cartridge print head. Install the BJ cartridge immediately after removing the cap and tape. Spilled ink can stain any surface; protect yourself and your work area.
    7. With the label facing outward, insert the BJ cartridge into the cartridge holder. Lower the blue cartridge lock lever until it locks into position.
    lockinpos.gif 8. Press thingtopress.gif.
    The cartridge holder moves to its home position on the right side of the unit and begins cleaning the BJ cartridge print head. This process takes about 55 seconds.
    9. Close the ADF (Automatic Document Feeder).
    10. Close the document tray.
    Note: If you need to unplug the MultiPASS, wait until the unit is in standby mode (date and receive mode displayed in the LCD). Otherwise the cartridge holder may not be in its home position causing the BJ cartridge to remain uncapped and dry out.
    Apr 11, 2009 | Canon MultiPASS C530 InkJet Printer
    Color cartridge errors
    The only reason for getting error "PU IN CARTRIDGE" is that the cartridge is not installed correctly. Follow these steps to reinstall the cartridge which will resolve the problem:
    Note: The same step can be performed for error "photo ink in use" but if this does not resolve the issue, you can try and change the cartridge.
    Feb 11, 2009 | Canon MultiPASS C530 InkJet Printer
    Loading the ink cartridge
    Please remember to rate other users who assist you for free :)
    How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
    Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
    Mp 460 tryin to insert ink for the 1st time
    Your post is in the wrong place. I almost got you the wrong directions. LOL
    Issue: How do I install the ink cartridge(s)?
    Solution: Installing / removing ink cartridges MP160 / MP180 / MP460
    Installing / Removing Ink Cartridges To print normally, install or remove ink cartridges in an orderly procedure. Installing ink cartridges:
    1. After confirming that the printer is powered on, open the scanning unit (printer cover).The ink cartridge holder moves to the replacement position.
      Note: After confirming that the scanning unit support is fixed into position, release your hands.
    2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
      Note: - Do not attempt to reattach the protective tape once you have removed it.
      - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
    3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
      *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
    4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
    5. Confirm that the ink cartridges are installed properly.
      <1> The ink cartridge is not installed properly.
      <2> The ink cartridge is installed properly.
    6. Fold the scanning unit support and close the scanning unit (printer cover).
    7. Wait until the preparatory operation is complete; it takes about one to two minutes.
    Removing Ink Cartridges:
    1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
    2. Press down on the semi-circular tab to release the cartridge and then remove it.
    3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    4. Fold the scanning unit support and close the scanning unit (printer cover).
    Nov 12, 2007 | Brother HL-2040 Laser Printer
    Epson Stylus Color 460 InkJet Printer Logo
    166 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
