How to get the last non zero number is the factorial of a given no. The given no. can have many digits even more than 100? I have to solve this problem in c++ using STL....
This is a common starter challenge in college and high school programming classes. While i'm not willing to code it for you, I can show you the methods you'll need to understand in order to approach the problem. The easiest way of doing this is by using a brute force method. Just keep testing the number to see if the remainder after dividing it with a number lower than it is zero. If so, it's a factor.
For example, If the number is 35 then pick a number just one lower than it that's not the number 1. Now divide the two numbers. 35/34 = a number with many decimal places after it, which means its not one of the factors of the number. However, eventually, you'll approach the number 7, and 35/7 = 5. This number has no decimal, meaning it IS a factor of 35, and also the largest non-zero factor of 35. Your algorithm can now stop, since it found the largest non-zero number.
Here's some pseudo-code:
int largestfactor(int number) {
int temp = number;
for(temp - 1; temp>=1; temp--) {
if (number % temp == 0) return temp
return temp
Something like that, with some bug tweaks will do it. The "%" sign is called a modulus. It's a standard c++ operator. Good luck, and remember to vote Fixya if you liked it.
The wikipedia article that helps you with better and more effecient algorithms can be found here.
Steven
