Paper stuck in laminator - Office Equipment & Supplies
    Genius:
  • 2,120 Answers
If the FILM is stuck...use a razor blade to **** the film and keep forwarding and reversing the rollers.
If the rollers are sticky try cleaning them with isopropyl alcohol and WD-40
Posted on Sep 16, 2008
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Lowell a4 laminator
slot can be opened and paper taken out
Nov 03, 2013 | Office Equipment & Supplies
Laminate top came up on an Ashley Dresser
If it is wood, sand it down and paint a laquer on it.
Feb 07, 2013 | Furniture
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Some one at work tried to laminate a card. when it did not come out she put in another sleeve thinking it would push the other out. smart uh! how do we get the 2 pages out?
If you were using GBC brand laminating pouches they don't need a carrier, if you were using another brand of laminating pouches, then a carrier is needed (something they don't clearly specify) and that's why the laminating pouch got stuck.
If you have had the laminator under a year, it should be under warranty, and you can call the company, and they will send a replacement, and they will probably then inform you of the above listed laminating pouch issue.
You may also want to try using the reverse button, but many times the pouches will get stuck between several rollers, and you risk destruction of the entire machine by attempting to take them out manually.
May 31, 2011 | Gbc HeatSeal H425 Laminator
Using a DWL-4A laminator I followed the directions my paper went in, and nothing came out the other side it must be stuck but the laminator dosent open how do I fix this?
You're lucky. My pouch won't even go in! Poor quality product and as I've had it in the box for so long before trying it, I can't even send it back!
Dec 11, 2010 | Computers & Internet
I have a Rexel LP30 Laminator and the paper has stuck around the rollers - is there a way to get this out without breaking it? Thanks!
Gently try cutting the laminate and running you machine in reverse while pulling on laminate. Be sure not to cut your lamintator rollers as scarring will leave marks on your jobs. Hope this helps . leave feedback
May 15, 2010 | Office Equipment & Supplies
My printer says "close document feeder cover". I don't know where this is
It is talking about the flap that is on the very top just above where one puts in an original to auto feed on to the glass, this access cover is required to be open and closed by the machine because it feels something is holding it open or its switch that tells it such is stuck. Maybe a jam from last original fed into it..
The cover once open check around for paper fragment and inspect little levers that hang down, one is stuck or there is paper stuck in Document feeder
I have found that often label bits, paper clips, punch bits and small corners of paper often get in the path, I use a piece of laminate cut so it has a v or a point and feed it in the document feeder, manually inserting it in the direction a piece of paper normal travels in it.
Push it all the way threw not pulling back (bad for it) to do so poke the point threw, you will need the top cover open and lift off the glass, so you can grap the point and pull the laminate threw.
Nov 04, 2009 | HP OfficeJet d145 InkJet Printer
Paper stuck in laminator reoccuring problem
try different paper it may be too thick!
Sep 22, 2009 | Office Equipment & Supplies
The lamination paper is stuck. never went thru the other side. How do I open it and un jam it? Please help ITS THE XEROX XRX-951L laminator. I couldn't find t n your list
you need to use the carrier (cardboard cover) that the lamination paper comes with.. if you dont use the carrier your plastic will stick to the hot rollers... you will need to take it apart and clean out the plastic.. easy to dow hen it is cold peels off easily... pain in the neck getting it back together as the wires in the front interfere with the front screw post...
May 26, 2008 | Xerox Phaser 8500/DN Printer
464 people viewed this question
jasbo
jasbo
