Question about Mitel Lands Phones
Trying to change passcode on Mitel 5215: worker has left without letting us know the code! Have put phone IP address into IE address bar but only get "page cannot be displayed". How do I access the Web Configuration tool?
  • mitelmatt May 11, 2010
    When you say "passcode" do you mean the Voicemail passcode or the Hot Desk pass code?
    Is this on a 3300?
The voicemail passcode. It's a 5215. I read the manual that says you can reset passwords by putting the phone's IP address into your web browser, but that just gives me "page cannot be displayed". Don't know what to do next.
Posted on Oct 21, 2008
How can I get a second hand Mitel 5215 to accept an IP address?
Your phone needs an IP address in order to communicate. Normally, it asks a "host" for that IP. You need to be connected to the internet for it to connect to the normal host, and your router should be willing to give it that IP address. "DHCP" is how devices ask for and get an IP address.
May 11, 2015 | Mitel 5215 IP Phone
Factory reset please help me to reset my Mitel
Reboot phone and hold down the down arrow key. This will put you in the programming of the phone. Use * and # to toggle thru until you see default . Then follow screen to save and reboot
Sep 18, 2013 | Mitel 5215 IP Phone
How do I reset my password?
if you go to voicemail then it will say hit "u" for user options, then hit "p" or "7" to change passcode.
i just did that(:
Nov 16, 2011 | Mitel 5220 IP Phone
I am trying to use a Plantronics CS70N headset with my Mitel 5215 IP Phone. I have the headset plugged into the headset jack on the back on the phone, but there is no head set button. Is there some...
First remove the headset cord from the headset jack. That is only used for corded headsets. Plug the short cord into the jack where the curly cord had been plugged into. The curly cord is now going to be plugged into the base of the charger where the picture is of a handset -- the curly cord goes there. There is a A/C adapter that is plugged in to base that is now plugged into the wall.
Good luck from Headsets Direct!
Jun 29, 2011 | Mitel 5215 IP Phone
Which pin on the network cable uses the voltage that power the IP Phone Mitel 5215
Though I can not confirm the phones voltage requirements, since all the phones I have worked with use 24vdc and passive POE (mode B in the Wiki link) here is the information Link
Feb 28, 2011 | Mitel 5215 IP Phone
Headset doesn't work when plugged into Mitel 5215 IP Phone jack.
You need to have a Headset button added and press it... or dial the headset on code. Contact your system admin or vendor to have the button added or to get the codes. This is something you can't do from the phone.
Jun 30, 2010 | Mitel 5215 IP Phone
DHCP DISCOVERY - USING OPTION 128 ERROR ON PHONE
The network switch isn't set up properly.Contact your vendor or network admin for setting this up properly.
May 26, 2010 | Mitel 5215 IP Phone
I need to reset the mitel 5212 IPphone passcode as the previous employee has left can you advise how I do this please as I need to set up voicemail
Hello...if u have access on mitel system then u can goto user configuration form then select extension# u want to edit...from there u can even delete the mac address and more..hope it helps
Nov 04, 2009 | Mitel 5212 IP Phone
Ip 5220 Mitel
You'll need to log into the voicemail server or PBX that hosts the VM and reset the passcode for each mailbox you're trying to access. If you have an embedded Mitel VM you can change the passcode by logging into the Admin mailbox then select option 2 to edit mailboxes, pick the mailbox to edit and follow the prompts until you have the option to change passcode
Jan 29, 2009 | Mitel 5220 IP Phone
5215 5220 and 5224
The Mitel IP phone downloads its firmware from the 3300 ICP on startup, You need to spesify what the phone is doing, ie does it start up at all or is the phone Dead,
If the phone does start it might have the wrong settings in the phone preventing it from finding the 3300 ICP, There is a Default to factory setting by interupting the phone on bootup.
Dec 07, 2007 | Mitel 5215 Corded Phone (50002817)
Lands Phones Logo
365 people viewed this question
Top Mitel Lands Phones Experts
Dustin
Dustin
David Payne
David Payne
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
