2000 Acura TL Logo
Anonymous Posted on Sep 13, 2011
I have an acura 2000 tl and the radio wiring harnes was cut off is there a diagram for this or is there a plug in adaptore so i can use the factory boss system and navigation with a diffrent radio
Anonymous
Level 3:
Genius:
  • Master 1,016 Answers
  • Posted on Sep 13, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1016
Questions
0
Helped
413251
Points
3013
Hi Alberto,
It will be difficult to purchase just the factory connector for the rear of your stereo and nav system. The best thing to do in this situation is to try and find a second hand radio loom from a car wreckers/junkyard and fit the radio loom in place or have a autoelectrician wire the second hand loom in place.As for the wiring diagram, I do have one but it is in 3 parts and you will need the factory plug to wire the loom into.Let me know how you get on and I will send you the diagram when you require it.
2answers
Wire diagram from deck radio unit acura tl 1996 3.2
Www.modifiedlife.com. has an excellent resource for car audio wiring
How to install Pyle radio PLR31MP
remove factory radio ,if you dont have the special tool to do this you can use coat hangers but I perfer using the factory tool sold at wallmart (the cheepest) or autozone push tools into holes on both ends of radio pull radio out. disconect wireing harnes and antenna wire.To install new radio you will need a wireing adaptor and a install kit. These must be spasific to your vehicle. you can buy these online Ebay , or Amazon or off line wallmart or orillys auto parts you will have to connect your new radio wiring harness to wiring adaptor.put install kit on new radio attach antenna wire connect wireing adaptor to original radio wiring push radio gently back into dash with install kit attached. enjoy your new radio. if this was helpful please leave good feed back.
06 acura tl horn diagram
On this website, you find horn wiring diagram for Acura TL 2006
Acura TL 2006 wiring diagrams horn
Where is the fuse box Acura 3.2 TL 2000?
On this website you find fuse box diagram and description for Acura TL (2000)
Acura TL 2000 wiring diagrams fuse panel CARKNOWLEDGE
Do you know the code to cut my radio back on for a 2001 Acura 3.2 tl?
The code is printed on a small card, which is inserted in a slot in the front of your owner's manual.
2answers
1996 acura 2.5tl wiring diagram
picture diagram of blower motor resistor for 96 acura 2.5tl
3helpful
2answers
04 acura tl serpentine belt diagram
there should be a belt diagram from a label either on underside of hood or on radiator support. That should help if you can do it yourself.
Top Acura Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Acura Expert? Answer questions, earn points and help others
