Question about HP LaserJet 1020 Printer
Change Printer Sleave
How change the printer slave
  • iamthekiller Sep 28, 2008
    yes i have the same problem...thr is a white streak in the middle
I dont know why today when i printed my word document with this  hp 1020 printer, it always comes out such pages with a faint colum. everything is ok, except in the middle there is a colum which is very blur (faint) starting from the first row down to the last row can anyone tell me why, thanks i have this printer for about one year, and actually i almost never cleaned it, so it got some dust too so is it possible to be the problem that i didn't keep it so clear,
Posted on Sep 23, 2008
How do I change dpi setting
Printers are basically slaves to the software and the drivers that connect the printer to the computer. Increase the dpi in the computer program and then check the printer driver for max dpi setting.
Sep 22, 2014 | HP Officejet Pro 8600 Plus e-All-in-One -...
Clicking by paper feed while printing
your printer fuser teflone sleave is damaged replace the teflone sleave
Jan 21, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
How can i set paper size to A4 in printer of model lexmark T650n
The paper size is set in SOFTWARE, the printer is essentially a slave...Change the paper size and type (like photo paper) in your software, like Word.
Mar 18, 2011 | Lexmark T650n Laser Printer
Printer is not printing
hello...........
It seems this is a problem of ink.....
Try to get a new cartrage................
If that is ok then check the driver whether it is install or not.............
If that dont work let me know ill give you detailed instruction .........
happy computing
Jun 21, 2010 | HP LaserJet 1020 Printer
Paper cringling and jamming on print. Drum looks worn.
this sounds just like a worn out fuser. pull the fuser out and inspect the rolllers if the orange roller (the pressure roller) has bad wrinkling or if the shinny sleave of the roller has slid off to one side replace hte fuser
Mar 08, 2010 | Lexmark Optra T612 Laser Printer
Need 93 ford F250 clutch diagram to understand how it works
It must a Diesel? Exterior slave cylinder? The double, or split, flywheel has is made of two major parts. One part is bolted to the crankshaft and there is a bearing that supports the other part of the flywheel that pressure plate bolts to. There are cushioning springs in the flywheel instead of in the clutch disc, it's not a very good set-up and they are prone to failure. "LUK Clutch Company", makes a solid flywheel and regular clutch for those trucks, there might other companies too. The clutch works the same way as any other clutch but, the reason it pushes hard is because the sleave that the release bearing (throw out bearing) rides on, is most likely galled or dry. That sleave is made of aluminum and they have a nasty habit of getting messed up, I don't remember if there are 3 or 4 bolts that hold that sleave on the front of the trans. At any rate that sleave is easy to replace once the trany is out of the vehicle, check the arm for wear and cracks too. If you don't want to pull the trans to fix it right, you might be able pull the boot out that goes around the clutch release arm enough to squirt some oil up on that sleave, that might get you by for a while.
Nov 22, 2009 | 1993 Ford F250
HOW DO I GET THE CLUTCH HYDROLIC LINE OFF OF THE INTERNAL SLAVE CYLINDER ON A 1990 FORD F 150 4X4 5.O
down by the tran look were the line gose in there is a white sleave that gose all the way around you have to push it in . it can be a pain in the neck.and iam shore they make a spelshell tool for it. good luck
Apr 30, 2009 | 1990 Ford F150
HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Feb 04, 2008 | HP Color LaserJet 2600n Printer
Squakey noises while printing
Mainly it from Fuser Section ,Your Fuser Sleave has damaged replace it with new one it cost some thing around 5-10$
thank you
Jan 30, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 1020 Printer Logo
53 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
