Question about Canon imageCLASS D761 Copier
Canon np6030 paper jammed at output...stuck at picker finger...
Pls i urgent need software of toshiba e-studio 282 hard disk
Posted on Feb 05, 2009
  • 3 Answers
I have downloaded service manuals, parts manuals, maintenance manuals, service mode, error codes from
Posted on Sep 15, 2008
How can I stop the paper from jamming
Be sure to load paper very carefully, removing and discarding any sheeets wrinkled or creased. Check the paper path, looking especially for paper dust or scraps of paper from earlier jams. Check the rubber sheet pickers as they may be worn or dirty. Check the paper path as thoroughly as possible, again looking especially for paper dust or scraps of paper from earlier jams.
Sep 08, 2012 | Canon imageRUNNER 2000 Copier
Canon gives error 03e
This error maybe cause of two reasons:
  1. The paper output tray is closed.Open it.
  2. Paper jam.Turn the machine off and on.Look through the paper output tray for any stuck papers and gently pull them out.
Hope this helps.Thanks!
Mar 24, 2012 | Canon MP280 All-In-One InkJet Printer
AF1015 copier - when copying it jams and the paper is like a concertina. Can you advise what to do.
If I understood, the paper looks like accordion and I pressune that this happens in fixing assy. This means that one of picker finger is broken or have loose spring. For repair you need to dismantle the fixing unit. Call service...
Aug 25, 2011 | Canon Office Equipment & Supplies
Paper is jamming extremely in heater section. what is the problem.
Is the jamed paper, look like "accordian" ?
If yes, then you have problem with bad picker finger ( its a plastic "finger" for separation and guidance of paper out of fixing assy ). just remove "bad" one, and it will work.
If paper is wraped around fixing roller, change fixing roller, bushings and check for any other damadges.
If its not any of this, send specific details.
Hope that helped.
Jun 27, 2010 | Canon imageRUNNER 400S Copier
Paper jam message...but no paper is jamming system
is a small finger plastic, stucked on the paper path, release-it and problem solved. (Is very fragile, so use a small tool to release)
Dec 29, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Displays paper is jammed message when there is no
There must be a bit of paper torn off and stuck in the sensor for the paper jam on the Output side of the printer. Look for a tiny bit of paper where one ought not to be.
Sep 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper jam
First of all...that number is not the proper model number, so clarifying that might help further, but regardless, the paper is getting jammed in the fuser and it sounds like it probably needs a heat roller and/or pressure roller replaced, and possibly the picker fingers
May 08, 2009 | Office Equipment & Supplies
LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon imageCLASS D761 Copier Logo
356 people viewed this question
old marine
old marine
