Question about Sharp XE-A404 PC Desktop
RS232 interface to PC
Dear expert,
How can I download data from Sharp XE-A301 to my pc with rs232 cable with hyperterminal? or  if I want write it in VB6.0 or VC6.0, where can I get the SDK for this product?
Can you send any suggestions to jansonlinlin@gmail.com
Thanks
    Problem Solver:
  • 9 Answers
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
http://www.startech.com/au/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
https://en.wikipedia.org/wiki/Null_modem
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
My cash drawer in not working
Kindly check the Data cable ( RJ11) if connected properly, connector points turned green. Try Changing it.
hope below links help you
6 pin RJ12 6P6C male connector diagram and applications pinouts RJ12 to rs232
Pinout cable and connector diagrams usb serial rs232 rj45...
Sep 13, 2012 | Partner Tech PT-8800 POS Terminal -...
How to connect ddx3216 to pc
You need to either connect it using a MIDI interface card and cables from the PC or you can use a RS232 serial cable which may be hard to find for your PC. It appears to use the 7 wire RS232 type connector at the mixer board end. You can get USB to MIDI converter devices from several sources.
Aug 12, 2011 | Behringer XENYX 2442FX Mixer
Symbol ls2000 hand scanner won't read barcodes. The laser lights up and it beeps when I scan but it takes in no data. I have tried the sets all defaults programming barcodes but all it does us make a...
If the scanner beeps just once after a scan, than he recognize the barcode and sends the data to the computer. If you dont receive any data, you are waiting for them on wrong interface. Data from USB or KeyboardWedge do come to Notepad/Word etc. The data from Serial RS232 Connection can you see only in Hyperterminal or similar application.
Sep 26, 2010 | Symbol LS2000 (ls-2000-i000ag) Handheld
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
CANT CONNECT TO THE RS232 CONSOLE PORT. WHAT IS
Just click on default settings in hyperterminal?? if u had not set any in ur router??
Mar 24, 2010 | Computers & Internet
I'm inputing ASCII via RS232 would like barcode printout
You will need to send the data using ZPL or the printer won't recognize it , if you don't have experience in this area print through the Zebra Print Driver should work. In your application use Barcode 128 as the font and see how it goes
Jul 24, 2009 | Zebra Z4M Printer
Magellan SL Scanner/Scale PC Connection
first go to posspecialist.com ok get a usb sr232 converter than it will work but not in vista with xp ok
May 19, 2009 | PSC Magellan SL
Problem with an usb-rs232 adapter
There is a good chance the weak spot is your serial to usb adapter. The signals are not compatible so the adapter has a chip and serial driver to convert the signals. If the adapter is not fast enough to convert the signals, you get an error. Here is some more info on adapters.
5 Steps for Selecting the Right USB to Serial adapter
Mar 04, 2017 | Televison & Video
Sharp XE-A404 PC Desktop Logo
528 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
