Output to Monitor and Keyboard.
You have replied me that Power Supply is dead. but Mouse is getting the power supply and Monitor is also getting the power but window is not going to start.....Is there any problem in CPU pin place ?
  • dobbelrr1000 Mar 18, 2009
    I need a batteri and a charger !
  • 724 Answers
If lights are lighting you supply is working...
Microsoft OS ? if yes,,,Do you get any beeping sounds?
If so the CPU is ok and and you need to define the beep code on boot. It tells you about the hardware there. If error beeps the computer will not start up...
You find this in a computer lingo reference manual of ask a search engine these questions. Since you got this far on line I expect you can see to it to find more info
You need to try a working borrowed monitor.
Sometimes that helps ...
Posted on Jul 24, 2009
  • 167 Answers
Motherboard is getting 12V, 5,2V from power supply. Probably 5,2V is dead. If you have a friend who will give you a power supply. Put in your computer and you will see that is the problem.
Posted on Sep 15, 2008
I changed power supply now I have no monitor keyboard mouse and no light on wifi board
It sounds like the power supply isn't powerful enough to properly supply all the power to the motherboard, you might have to get a more powerful one. It could be that the power supply is faulty too.
Jun 25, 2015 | Computers & Internet
Why wont the mouse,keyboard and monitor not work after cpu,pwer supply install...
If the motherboard used to work with the old cpu and power supply, but does not with the new cpu and power supply, then probably the cpu or power supply is bad.
Why did you change the cpu and power supply?
If the power supply went bad, it could have overloaded the mother board as well as the old cpu.
If you think the old cpu went bad, how do you know it was not actually the motherboard that went bad?
All I can suggest is that you double check all the connections.
If you have USB mouse and keyboard, try a DIN connected pair.
If you are using the onboard graphics, try a PCI express card instead.
Tell us if there is any front light activity from the power switch, drive, etc.?
Dec 21, 2010 | Biostar P4M900-M4 Motherboard
ASUS P5S8000-VM/S no bios screen no beeps
From the description of the problem, it seems that either the power switch of your PC or the power supply cable is faulty. Also, please let us know if the motherboard LED is glowing or not. Do reply for more assistance.
Thanks.
Jul 21, 2009 | ASUS P5S800-VM Motherboard
Replaced my power supply, now keyboard and monitor wont work.
Believe it or not, if you have a floppy drive in your computer, try unplugging it and disconnecting the data ribbon. Many times, damaged floppy drives can short out motherboard functions and even prevent computers from powering up. If that doesn't fix it, then get a usb keyboard and mouse set (wireless would be fine) or borrow some, and see if they work. If they do, then the power outage damaged the PS2 ports.
May 25, 2009 | E-Machines eMachines Monitor E15T4
Keyboard, mouse, screen do not function?
you may have a bad mother board or power supply,however try a few of these,bare bone the system,no mouse keyboard,only monitor,remove all internal cards,power on.If no go remove memory ,power on if you get beep tones the motherboard is good.Question for you did the fan turn during these steps.Do you have a amber light on the power button,if you do the answer is you have a bad power supply.
Good luck
May 16, 2009 | Dell PowerEdge 1600...
No video mouse or keyboard but all power and leds are working
there are several problems to this case.
1. check the 24 pin power supply and be sure to plugin the 4 pin power supply just beside the cpu.
2.ram not placed correctly
3.Power supply inefficient.
4.BAD BIOS SETTINGS Try resetting bios i.e.., CLEAR CMOS or remove onboard battery, wait for a while and then place it again.
5.RAM is damaged
6. Highly overclocked cpu - resetting bios works
Check all the above to see whether your computer comes online.
6.
Apr 22, 2009 | ASUS P5GC-MX/1333 Motherboard
On first power up, no video, no sound.
hi
*********** board dead
hope ur smps &ram also ok ......
pl z check motherboard near pc service care.......
Jan 12, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Power supply is dead. Need new one. It's not expensive.
good luck.
Sep 15, 2008 | Mercury PVCLE266 Motherboard
Power Supply
Check all power cables plugged into M/board if these are correct
remove all hard ware
hard drives / cd player and anything else
except for video and memory and test to see if it boots. If it does, one of the removed hardware is faulty if it does not then you have M/board failure
Aug 02, 2008 | E-Machines Emachine T5026 power supply **...
Computers & Internet Logo
664 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
