Anyway, with regards to your issue, error 523 reset means a "System process died" You'll need I would reload the entire handheld OS again.
1. Install the software from the CD (that you received with the device), or download it from the service provider .Depends on your service provider your using (AT&T).
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Blackberry phone (since am sure that's what you have!)...
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
Let me know if it works..
Good luck.
And thanks for using fixya.
SOURCE: my blackberry 8520 cure app error 523...
1. Install the software Desktop Manager
4. Connect Curve 8520
7. The whole process should take about 1 hour
