Question about LG 42PX4DR 42 in. Plasma TV
LG 42pc3r, Starting problems.
When I try to start my tv it clicks two times then nothing then it clicks again. then it tries again without my interference. to stop the tv from trying again I have to unplug it. This problem doesn´t occur everytime and when it starts everything works just fine.
  • Anonymous Dec 11, 2008
    I have the LG/DVR combo and it is just 2 years old and clicks, has a delayed picture which then blacks out and the TV is just black. I called LG and they gave me a repair number. I called and they said $80 to look at it, if I pull it off the wall and take it to them. Darn!
    Scholar:
  • 86 Answers
First thing to try is a power drain:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
If this doesn't solve the issue, it sounds like your TV's connection between the power supply and the mainboard is defective. If the power supply was shot, you would hear nothing at all. I hope the above step helps.
Posted on Oct 15, 2008
My lg dryer want start up it just clicks three times when I press the start button
On older models the selection switch starts to wear out, click both the selection switch and timer switch around in a full circle & try starting again. If it is an electronic model, try unplugging it and let it sit 10 seconds then plug it back in and see if it reboots properly. A power outage or brown out may have effected it.
Nov 12, 2016 | LG Dryers
LG 42LD550 LCD - Internet connection problem
After the network is connected to the TV, you have to go into the TV’s network menu to complete the setup process.
If you look in your owner’s manual starting on page #55-#57, you can read the direction to walk you through the wired network setup process.
It should be very easy to setup as long as your router has the DHCP turned on. That allows the TV to automatically assign it an IP address on your network.
If the DHCP is not turned on in your router, then the TV’s IP will have to manually entered by you.
May 20, 2010 | LG 42LD550 42 in. TV
Problems starting up my LG RH188H
I had the same problem. After googling I found that the HDD might be faulty so I unplugged the device, brought it upstairs to unscrew it (to change the HDD for an empty new one). One last check before I really unscrewed the cover - and the recorder started again! After 5 minutes the 'please wait' returned. So, did the same thing again, tried a few times, and the recorder started. Then, I imediately reformatted the HDD, and the problem is now gone.
May 23, 2009 | LG RH188
Clicking starter=car not starting
Regardless of the battery age,sounds to me as if you have a drain on the electrical system First thing to do is completely recharge battery. An initial quick inspection might show a light staying on, whether it be a door , reading, glove box, or trunk lights, among many other things. If nothing is obvious an electical reading of the system while removing and reinstalling fuses will show the circuit causing the drain, Hope this helps
May 04, 2009 | 1995 Pontiac Grand Prix
the battery is located under the rear seat, check battery connections. if connections are tight replace starter.
Mar 29, 2009 | 2002 Cadillac Deville
1987 F150 302 ci. EFI, Automatic, Was running good. Next morning NOTHING! Wouldn't start or crank over? Just clicking and buzzing, Headlights OKAY. Tried jump starting... NO GOOD. Took battery in... Was...
try over riding the starter relay on the fender ,it has one there right?. dont go to a mechanic yet. the engine aint seized. if it doesnt have this relay then i would get the alternator tested. if you want to test it yourself it can be costly for the right equip. autozone usually tests for free. i dont know were you live so if theres not an autozone. let me know if you cant get it tested.
Feb 22, 2009 | 1987 Ford F 150
LG TV Making Bad Noise
have u tryed new cables for sound 1st
Feb 03, 2008 | LG 42LC7D-UB Television
LG rear projection Tv
Try resetting the TV by unplugging it for 2 minutes then trying again. If it still has any problems then double check your connections to the TV.
Feb 27, 2007 | LG RU-52SZ51D 52" Rear Projection...
LG 42PX4DR 42 in. Plasma TV Logo
291 people viewed this question
Computer Repairing
Computer Repairing
