You need to install the softeware first with the printer unplugged from the computer!
Insert your softeware disk and restart your computer, if computer doesn't detect new software when it is rebooting....than go into your control panel...click on install new software.
Once that is installed, you'll need to restart again with the printer hooked up this time.
Again, if computer doesn't detect new hardware, go into control panel, click on install new printer, you will have to select the make and model, or if you have the disk, select have disk, then next...you computer should install the hardware for you printer.
After installed, restart again...to see if if new software and hardware is detected and is being installed.
Go to your printers, from your control panel, and see if your printer is there, if not select, add new printer, it will take you through the process from there. Make sure you select this to be your default printer!
Happy printing!
