Portable Harddrive - Works on Newish Lappy, not on old Thinkpad
Got a portable harddrive, PCMIA card USB 2.0 adaptor and the power lead for pcmia card. Drive has enough power, but is not recognised in my computer (running XP). The drive works fine on my desktop and my 3 yr old laptop. The laptop I am trying it on is a IBM Thinkpad X20 - 2001 I think. It only has 64 RAM, waiting on a 256 RAM stick to arrive if that will help.
    Scholar:
  • 147 Answers
Time to install an XP driver for your PCMCIA card.
Posted on Sep 16, 2008
Why can't my Panasonic DVD recorder read my portable harddrive? I want the DVD record to read the harddrive?
hi anonymous, it may well be that you need to change settings on your DVD Recorder and/or on your TV. On my LG 42" TV I need to select the input mode ie. Movie, USB, music etc, as necessary. Maybe your DVD Recorder or TV can't handle the file format on you Portable Drive, check the manufacturer specs.
Jun 08, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
My vivo tv wont accept portable harddrive through usb ports
that because your TV or TIVO doesn't have the necessary decoder for the HDD and that's why it only works with the laptop
Feb 23, 2013 | Computers & Internet
About 2 months ago I bought a samsung s2 portable 1Tb. It has worked fine until yesterday. It slipped down from where it was laying (while plugged in and running) and was hanging the 20 cm usb-cabel. Now I...
Hanging by the 20cm USB cable?
The cable could be stretched, and wires broken inside.
The cable to small circuit board, inside the case, could have broken solder joints.
The circuit board inside the Samsung's case could be broken.
Inside that small outer case of the Samsung portable is a laptop size Harddrive.
The harddrive measures 2.5 inches across in width.
(6.4cm. In comparison a desktop size harddrive is 3.5 inches across in width, or 8.9cm)
The harddrive is a SATA unit also.
This is a general example of a 2.5 SATA harddrive,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148591
Inside the outer case (External Enclosure) is also a small circuit board (PCB)
The harddrive plugs into the small circuit board, and the circuit board has a USB cable attached to it.
(Or there is a small cable from circuit board to harddrive. Then a USB cable to the circuit board)
I would suggest removing the 2.5 SATA harddrive, and install it into an economical external enclosure.
Example of a 2.5 SATA External Enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
Basic guidance in removing the Harddrive from a Samsung S2 Portable,
1) It looks as though the outside front is a thick cover like a label. It may be that you peel back the corners, and there will be a screw in each corner.
(For example; Where it states Samsung. Go to the right corner. Does this cover-like material peel back? Is there a screw underneath? Remove it.
Go to the opposite corner. Now above to the left and right corners)
The unit looks to come apart in two halves.
Might just be held together by sticky tape.
Here are some videos performing opening the external enclosure, (Case) of other external portable harddrives,
1) http://www.youtube.com/watch?v=dMzRYCZXVEs&feature=results_video&playnext=1&list=PLC129A4F797CCC09E
2) http://www.youtube.com/watch?v=Y2vUMO2mGLE&feature=related
There are other related videos. In general most are not very professional, but get the job done.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 18, 2011 | Samsung S2 Portable HX MU010EA 1 TB...
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
My Portable hard drive will only work on 1 computer
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jun 03, 2010 | LaCie Computers & Internet
After a time, Computer not recognizing portable harddrive
Reformatting will be our last option and there are a number of steps that you can try to fix this.
  • Try plugging it in on a different USB port
  • Check the USB cable, try replacing it and see if it works
  • USB ports on your computer makes use of power, so if you have multiple USB devices plugged in, the portable hard drive might not be receiving enough power. Try plugging it in without your other USB devices, except the mouse of course
Please leave me a comment for this.
Jun 03, 2009 | SimpleTech Signature Mini 320GB External...
3d video
Sorry, but no. There isn't any type of external video card for these, and the internal card is integrated into the motherboard.
Aug 13, 2008 | IBM ThinkPad T20 2647 Notebook
Ethernet controller
Is this an external PCMIA card that you want to install into your laptop, or are you opening up the laptop and modifying the motherboard?
If its a PCMIA card that you are looking for, then I would suggest the D-Link DFE-690TXD PCMIA Ethernet Adapter. I have one that I'm using with an old HP notebook that has a fried internal network card. You can buy it from newegg for about 32 bucks with shipping.
Here is a link to it: http://www.newegg.com/Product/Product.aspx?Item=N82E16833127111
Mar 29, 2008 | IBM ThinkPad T40 2373 Notebook
Airport Failure Notice on Mac
what u meen built in wi fi adpoter in labtop dont work in air port proably need upgard eto linksys n pcmia card slip in on side ok thx nick
Feb 09, 2008 | D-Link DI-634M Wireless Router (DI634M)
Wireless connection problems
I would see if buying a cheapy PCMIA wireless card and trying that out.
It sounds like your wireless card might be screwed up. And there are so many things that can interfere with those things. They are kind of finicky.
Definitely look into getting a PCMIA or USB wireless device and try it out. I personally wouldn't buy something that was pricey and would try and get something reasonable. REMEMBER 802.11 is backwards compatible (G is compatible with B AND A) so you don't necessarily need the newest greatest thing.
Best of luck.
~Ominious Depression
Jan 07, 2008 | Toshiba Satellite M45-S265 Notebook
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
