Microsoft excel Formula
I'm finding problem to comeup with a formula for the below problem assocaited with 2 columns. Column A has 5-6 various strings (AA,BB,CC,DD,EE) and Column B has some fields empty and some non empty. The non empty ones in Column B are always prefixed by String "CSC". Now i'm trying to find out how many of each type of Column A are present which is having empty fields in coulmn B.
For this i tried the blow formula's which is not working. Pls help me.
=SUMPRODUCT(--(U2:U3395="AA*"),--(Y2:Y3395<>"*CSC*"))
  • 45 Answers
Create a dummy column (columnC) containing columnA&columnB
use countif at columnD to count the number of observations per combination of columnA and columnB (in particular those with blank entries in columnB).
Posted on Nov 21, 2008
When i copy a sum formula in excel the first cell does not remain the same it increments by 1. how can I prevent this?
There are 2 types of direct cell references that you can use when you're writing formulas: Relative References & Absolute References.
A Relative Reference is the address of a cell (e.g. A5). When a Relative Reference in a formula is copied from one cell to another, the Reference gets changed automatically. e.g. If you put a formula in cell c5 as A5+1, when you copy this from c5 to c6 the formula A5+1 will automatically change to A6+1.
An Absolute Cell Reference does not change when its copied to another location. As in the example above if the formula in cell C5 is written as $A$5+1, if you copy this formula from C5 to C6 it will remain as $A$5+1 (NOT change to $A$6+1.
The $ sign signifies Absolute, and can be applied to the Row reference, the Column reference, or both Column & Row (as in the example).
Oct 17, 2014 | Microsoft Excel for PC
How to add % (Percentage column ) in the excel
The formula is 200/700 equals the percentage;if you're in columns a, b, and c, the formula in c1 will look like:
=b1/a1.
Then you can format the cell to show the number (.2857) as a percentage (28.57%).
Jan 03, 2009 | Microsoft Computers & Internet
Count how many times a value appears in a column, based on anothe
Go to the cell you want this total in.
Type this formula:
=SUM(IF(Sheet2!C1:C10="EME",IF(Sheet2!N1:N10=1,1,0)))
make sure you end the formula with CTRL - SHIFT - ENTER which makes it an array formula. If you forget, go back to the cell with this formula and press F2 (to edit the cell) and press CTRL - SHIFT - ENTER to convert it to an array formula (Excel will show a little {...} around the formula).
Dec 21, 2008 | Microsoft Excel for PC
Need to use the VLOOKUP formula for more then one column
You probably need to organise your pricelist sheet so that you only have 2 columns, product and price. If this doesn't fix you, please provide the syntax of your vlookup code.
Dec 10, 2008 | Microsoft Excel for PC
Excel will not displaying the results of a trend array formula
Hi Griffnz,
Your "known Y's" or 'values' are in Column B. This is the first array in the Trend formula.
Your "known X's" or 'months' are in Column A. This is the second array in the trend formula.
The trend formula is supposed to give you a projection of what the rest of the values in Column B will be over the next few months (usually continuing cells in Column A). The cells you want these values to show up in represent the third array in the formula.
Thus, your formula should look more like: '=trend(B3:B14,A3:A14,A15:A18)'
However, your formula is leaving out The values in B and adding values from C - -- but there ARE no values in C. Apparently, C is where you want the values to appear. In that case, the C array would be the third array in your formula. This would look more like '=trend(B3:B14,A3:A14,C3:C14)
If this doesn't make sense, let me know.
Sep 30, 2008 | Microsoft Excel for PC
Excel formula
I'm assuming you'd like to assign a numerical value to cardinal references (1st, 2nd, 3rd, 4th, etc.).
Best way to do this is to create a quick lookup table on a separate sheet of the same .xls document. Down at the bottom of the page, click on Sheet2 and create a quick table where column A has 1st, 2nd, 3rd, etc. and column B has your values.
Now click back to Sheet1 where your data is and in A2 put this formula:
=VLookup(A1, Sheet2!$A$1:$B$x, 2, FALSE)
Note: replace the lower case x in the formula above with the number of the last row of data in your lookup table on Sheet2.
You can copy and paste this formula down the column to calculate your other values.
Hope that helps!
Terry
Aug 30, 2008 | Microsoft Excel for PC
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
=INDEX($C$2:$C$5,MATCH(D2,IF($B$2:$B$5=E2,$A$2:$A$5),0))
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
=INDEX(HomeVal,(MATCH($A$1,StAddress,0)),(MATCH($A$2,Dates,0)))
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
Lookup,s
If you can move your name column (C) to the first column, you could leverage the VLOOKUP formula pretty easily.
To do this, do the following:
1) Move the C Column to be the A Column, shifting all other columns to the right.
2) (optional) Insert a new row at the top of the sheet (to hold the formula & seach value)
3) Use A1 as your search field.
4) In A2, enter the following formula:
=VLOOKUP($A$1,$A$2:$C$6,3,)
Describing above parameters, in the formula:
$A$1 -> the search field (name your looking for).
$A$2:$C$6 -> The table/grid you wish to search and return values from. The left most column (A) must contain the values to be searched.
3 -> is the column number (A=1,B=2,C=3, etc) within the table/grid to return.
If you cannot make the name column your first (A) column, there are more complex ways to do this. For instance, create a new sheet which redisplays the info in the structure easier for this method, and perform the VLOOKUP on that data. Other options might exist in creating a complex formula that would get you what you want.
Also, if you can sort column A (names) it would find results faster, if your data set is large.
Feb 03, 2008 | Microsoft Excel for PC
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
