SOURCE: Modem Problem?
In order to really test your modem you need to call more than just 1 (your ISP's) number. If you are not getting 56k connects, you should try your modem with other local/toll/toll-free numbers. This is a list of some toll-free numbers, the 3Com "Line Test" Number (a toll-call), and links to various ISP local access number listings Setting up an account with a Free ISP is another way you can test and isolate modem/ISP problems.
1-847-330-2780 - USR Linetest number - this is a toll call; if you log-in as "Line Test" with a v.34 modem, it will attempt to determine if your line will support 56k connections.
1-847-330-4569 - US Robotics' V.92 Test number - this is a toll call; the server is a 3Com Total Control HiPer ARC running V.92 server side code that supports PCM upstream.
The following numbers use toll circuits but are free to the caller (as long as you don't log in):
1-800-245-3828 - (Canadian weather BBS)
1-800-590-4857 - (IBM Global network access # x2 and V.90 3Com Server)
1-800-784-3638 - (Netcom - supports V.90)
1-888-861-8490 - (MCI/Worldcom))
1-888-245-0113 - (AOL access x2)
1-800-716-0023 - (AOL alternate access)
1-888-296-3892 - (AT&T Worldnet accessV.90,x2)
1-800-638-1483 - (GTE Net access - V.90/K56Flex Ascend Server)
1-800-572-1959 - (Compuserve V.90,x2)
1-800-350-6885 - (Earthlink - V.90,x2)
1-800-853-7921 - (Earthlink - Flex)
1-800-534-7097 - (Earthlink - Flex)
1-800-304-4226 - (Shore.net - Flex)
1-800-320-4509 - (Ascend 56KFlex test line)
1-800-779-2966 - (Used to be MCI)
1-800-846-7562 - (Gateway BBS)
SOURCE: MODEM ON HOLD-
is pc showing this modem in control panel under system icon? now try uninstalling Modem and reconnecting it and plug in phone line......if software cant detect it on boot up ...then it sounds like a defective modem.....
SOURCE: Agere Win Modem Driver Version 8.30.0.0 vs V.92
you have a v.92 modem even if it lists as v 90 just run a windows update,, look for hardware updates, , if none comes up for the modem you should be good .
the last update was to 8.30 for v92. .. v90 etc. . it wont make that much of a difference in speed. .. however
A phone line filter WILL make an amazing difference, having worked for a dial up isp before , trust me , they help alot. .. its worth 12-22 dollars from any radio shack or maybe even walmart.. . i've seen them in home depot as well but don't spend more than 25 dollars. .
"phone line filter" look for it on radio shacks website
http://www.radioshack.com/product/index.jsp?productId=2103593&numProdsPerPage=60&retainProdsInSession=1
the picture is accurate.. not sure of the description, that thing is not for two lines.. its a a single male end --- to --- female end filter no bigger than a permanent marker. .
good luck. . oh.. it should increase performance from say 34k to 48/56k orn your modem. .
good luck. . its the next best thing to having new lines put in... to your house.
or usb broadband from cricket.
