Question about Mercury PVCLE266 Motherboard
Output to Monitor and Keyboard.
My brother was doing some work on Computer without using UPS. Suddenly electicity gone and PC turned off. When I tried to strat this PC with bootable CD, output was not coming to Monitor. And Keyboard was not getting electricity power. I checked this Keyboard with some other PC and it was working fine there. Please help me out
  • 167 Answers
Power supply is dead. Need new one. It's not expensive.
good luck.
Posted on Sep 15, 2008
My monitor won't come out of sleep mode
when the computer enter the sleep mode, it is possible that the computer remove the check mark from this output activation.
When you have multiple ouptut like a internal LCD and output on a monitor, when going into sleep then waked up, laptop reactivate the internal LCD without reactivated the secondary monitor.
you could need to go in desktop property and reactivate the secondary monitor with the check mark listed : Activate.
If you only have one monitor but still a dual output card or two separate video card same thing can happend. try to connect the monitor on the second VGA or HDMI output and see if the video goes there.
then reactivate your secondary output and make it principal.
Does also happend when your computer is connected to a UPS power and your monitor is directly on the sector. (laptop issu also)
if a brief power outage arrive then the monitor shut down (no power) and the computer continu, as there is no monitor on the output any more Windows will automatically deactivate this monitor. when power goes back, this output is no longuer providing video. I suggest putting the monitor on a UPS as well.
Jan 03, 2014 | Westinghouse Electric L1916HW 19" Monitor
Problem in Samtron 45Bn Monitor
Try connecting the monitor to the mains instead of the UPS.
If it works OK then the problem maybe the UPS and that it is very close to the max output of the UPS.
If not then the monitor is faulty.
Mar 12, 2013 | Computers & Internet
I have HCL Beanstalk Desktop, Monitor - Samsung Syncmaster 794MG. I don't have a ups. I get frequent powercuts in here resulting in interrupted shutdown of the computer. Sometimes while playing a game...
You seem to have a corrupt display card. Is it on board or do you have a separate graphics card installed in your PC. Either way on restart graphics processor is not turning on. What does the Power and HDD indicator on the PC show during boot up. You could also have damaged the Hard Disk because of your abrupt shutdowns. You can open the side cover and try disconnecting the HDD power (Yellow, Black & Red ) cable and IDE ( 40 pin flat ribbon wire ) cable and try restarting. If your monitor starts up and shows BIOS page you have a faulty HDD. Also see if the processor fan is a working when you start the PC. If not you have a failed mother board. Are you getting the boot up RAM beep. If not before you do any of the above mentioned things Just pull out the RAM ( with PC unplugged ) and reinsert into the slot. It might get your PC working after all
Mar 08, 2011 | MSI Computers & Internet
I have speakers plugged into my phonic powerpod 820 right now but I want also to have the output of the mixer to go through an instrument amp, is this possible? If so, where do I connect the instrument amp...
Yes it's possible. I'm assuming you'd like to use the keyboard amp as a "monitor". In which case, take a 1/4inch TS (instrument cable) jack out of "Aux Send" into the input of your keyboard amp. Make sure the keyboard amp is turned up to a good level and that the Master SEND is turned up on the Desk.
Now you can make your own "monitor mix" for on stage use without effecting the F.O.H mix by turning up the aux pot (knob) on each channel you use.
You can use the CTRL ROOM output also, but make sure it's not giving a "Powered Output" from the internal amplifier in the mixer as you will damage the keyboard amp.
Jan 16, 2011 | Phonic Powerpod 820 / S712 PA Package
Sunfire v480 when powered on not showing anything on monoitor server was working last 4 years without any problem
Dear,
If your server came up without key board and monitor on last boot, you wont get anything by connecting monitor. you have reboot the server by making user, input device=keyboard and output device=monitor you can see this value by using eeprom command from os you set this value eeprom input-device=keyboard eeprom output-device=monitor
Jul 13, 2009 | SunFire V480 UltraSPARC III...
My monitor ,keyboard,and mouse dosen't work . my computer is a gateway GT 5058
The fact that the monitor, keyboard and mouse don't work points towards a bad motherboard. If you can hear fan's running, see lights on the front of your PC then you are getting power to the motherboard.
Mar 15, 2009 | Gateway GT5058 Desktop PC
Problem in OS
If you are using the round plugs (PS1) then mouse and keyboard sockets are different, probably keyboard socket is broken.
If you are using usb, and mouse works on same usb port, then keyboard is faulty , even if it works on a different PC, probably a faulty contact inside.
A keyboard is an inespensive part , better buy a new one.
Sep 15, 2008 | Computers & Internet
Powering up problem on UPS
about your first problem it is not normal.you should check it out with a qualified professional.
after repairing it will work nicely
Apr 02, 2008 | SAMTRON 55V 15" CRT Monitor
Software for windows xp
Hi, your quite right that the original Fenton software doesn't work with and in XP. Since the reason for the software is simply to monitor certain conditions of the UPS and timer auto shutdown then running the computer plugged to the UPS even without the software would still make the UPS work. Of course this will only hold true if you are using the PC like a regular unit and not as an unattended computer. More information maybe gleamed from their website (http://www.fentonups.com/Support___Service/H___S_FAQ_s/h___s_faq_s.html#Operating-Systems). Hope this be of some help to you and pls post again how things turn up.
May 17, 2007 | Fenton Technologies Fenton PowerPal L425...
Mercury PVCLE266 Motherboard Logo
46 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
