Question about Panasonic Televison & Video
Set top box Panasonic TU-HDT104A. Cant change from channel 0. Have tried using remote and channel buttons on device. Have unplugged device completely and tried setting it up again but it just flickers between 0 and the channel you are trying to switch to then ends on 0. The IR led flashes all the time. Do you know if something could be blown or could there be any way of resetting the device to fix the problem?
techman
  • 3130 Answers
SOURCE: Flickering blue picture
I'm afraid you could have a power supply problem causing the optic engine and light not to work correctly, or you could have a bad DM board, or a bad light engine. the two latter troubles are very expensive to repair. :>( Good Luck
Posted on Jun 19, 2007
SOURCE: set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Posted on Nov 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: mitsubishiWS65511
You have the V21 chassis when the led blinks constantly you need the V21/V19 DM repair kit which has the parts and step by step instructions with pictures on how to do the repair. And its less than 40.00 for the entire kit with free shipping. Here is the link its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Posted on Aug 14, 2008
SOURCE: Romote control not working
1. The owner's manual is available online:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
Download the manual under Operating Instructions.
2. To remedy "SET1" problem, Press 1 & Enter at the same time.
Hope this helps
Posted on Aug 19, 2008
  • 31 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Posted on Oct 26, 2008
Tv will not change channels. Batteries are new. It worked fine 2 days ago.
If the remote you are using will control several devices (TV, DVD player, cable set top box, etc.), make sure you have pressed the TV button, before you try to change channels. Sometimes another device button gets pressed by mistake, so the incorrect codes could be sent to the TV.
Mar 15, 2016 | Televison & Video
My dog stepped on my remote and now my tv is set at 480 for all channels instead of the 720 like it use to be. My channels are not sharp anymore. How can I fix this
This may have been changed by pressing a button on the TV remote or more likely to be a button on the remote (or device itself) of the a Sat TV, Cable TV converter or other set top box - unless you're using an antenna.
You're looking for a button that is called "Resolution". What source are you trying to watch? Is it Antenna, Cable Box, Sat Box, etc. - what is the make and model of this box and the TV?
Oct 22, 2015 | Sharp Televison & Video
Use a panasonic tv/vcr combo in my kids room, lost remote long ago. Never had any issues and then suddenly this popped up: CHANNEL/CLOCK AUTO SET Connect antenna cable and if you use a cable box, tune it...
Try unplugging the unit, and leaving it unplugged for a while. Also, press all the buttons while it is unplugged..
It is possible - hopefully - that doing so will "wipe" all the ongoing processes "away", and you'll get back to normal operation.
It is a crude form of "rebooting", and it does indeed work for many different devices. Just unplug it for 30 minutes
Mar 24, 2015 | Panasonic Televison & Video
Not all buttons on All for one URC-2981 remote control working for Sinotec TV
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Dec 30, 2013 | Televison & Video
My rca is stuck on channel d9-1 and all buttons only control my volume please any answers
Try to unplug set and whatever is being used for signal from power, if set returns to normal operation you may have to delete that channel from the set memory.
Cable or Sat boxes can cause this issue by confusing the micro processor in the set.
Dec 03, 2012 | Televison & Video
UNIVERSAL URC-60500R01-11 TV DTV REMOTE CONTROL
http://www.maplin.co.uk/media/pdfs/A79HQ_manual.pdf - Manual for ONE-FOR-ALL URC-1625. Replace "MAGIC Button" with the "OK Button" on your URC-060500R01-11 remote control. This worked for my TVONICS MDR252 REMOTE URC-60500R01-11 and Logik LCX17LN2 TV using code 0880.
Oct 12, 2012 | GPS
Trying to program memorex dvd. cant find code, HELP!
Hello
The manual of the remote control you speified here contains no codes lited. But there is a possiblilty to find out the code by search method. If the device you wants to control with this remote control has codes stored in the remote memory, you can exit it by code search method.
Code Search By Brand.
Lets you search for a code for a specific Brand within
the Code Library for a particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the SETUP button until the red
indicator remains on, then release SETUP button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press and release the numeric button (0-9)
corresponding to desired Manufacturer (see table on
code list sheet). The red indicator blinks off once.
Note, pressing "0" performs a full library search same
as normal Code Search Method on previous page.
5. Press the CHANNEL UP button ((or POWER or
PLAY (VCR only)) repeatedly until the device to be
controlled changes channel. The red indicator blinks
off with each button press. If you accidentally
overshoot the code required, press the CHANNEL
DOWN button to backtrack through the library until
the device changes channel. Pressing CHANNEL
UP changes direction to forward again.
6. Press and release MUTE to install the code.
Brand Search Method entry is now complete.
Note: When all codes under a Brand have been searched
the red indicator flashes rapidly for 3 seconds.
Try this. Good luck.
Apr 07, 2011 | Philips SRU3004 Remote Control
Universal remote code
I just bought one of those remotes to use on a Magnavox VCR because the buttons on the original remote are difficult to read (grey numbers on grey buttons).
The TV codes for Panasonic are: 0171, 0148, 0054, 0170, 0062, 0374, 0381, 0437, 0950, 0003, 0070. Good luck.
I had no luck with any of the codes given, so I tried the "Programming with Code Search" method and it worked.
1. Turn ON the device manually.
2. Press and hold the "P" button until the red light stays on.
3. Press and release the desired mode button (TV, VCR, etc.) The red light blinks, then stays lit.
4. Press Channel Up button repeatedly (up to 300 times) until the channel changes. (If you accidentally overshoot, press Channel Down to backtrack.)
5. Press and release the Enter button to set the code. (Mine doesn't have an "Enter" button, only an "ENT" button the left of the "0" and that didn't work, but I found the "M" button in the middle worked.)
Nov 09, 2008 | Televison & Video
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Televison & Video Logo
122 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
