Fax machine In one of the offices I work in, theres a HP printer/fax/copier all-in-one. However when I try to send a fax, it dials out but doesnt seem to send anything. I dont know how to fix it, can anyone help?
    Scholar:
  • 73 Answers
1)Disconnect the power cord from the rear of the HP Fax machine.
2)Verify that the phone cable is fully inserted into the fax machine. If your model has a removable Line Interface Unit (LIU) where the phone line plugs into, verify that it is securely snapped in place.
3)If the HP Fax model belongs to the HP Officejet R80 Series , verify that the cable which goes from the Automatic Document Feeder assembly to the rear of the HP All-in-One base is connected.
4)Reconnect the power cord.After the fax reinitializes and it is ready, try to send and receive faxes again.
Posted on Sep 15, 2008
I cannot figure out how to setup the fax that came with printer
Hi Vallarie
Verify that the phone connector on the wall can carry a phone call!
Connect a phone & prove that you can dial out.
Remove phone.
Use a short phone cable to plug in to the Printer then into the phone connector on the wall.
Put the printer in fax mode, then use the printer keyboard to dial a phone number. If that works, your almost there.
Scan a document & send to the phone number.
If that dials out... OK. Then try sending to a phone number with a known Fax machine at the other end. When the two fax machines start communicating through "tones" then the document will be sent as a Fax.
Cheers
Trevor
Setting Up the Hardware for Faxing on an HP LaserJet Printer Did Did you find this Helpful....
Then how about a "thanks" or Tick of Approval?
It's the only payment we get
Sep 20, 2015 | Canon PIXMA MX472 WIRELESS OFFICE...
The all-in-one printer fax will receive a fax with no problem, but will not send a fax. It will scan the document, dial the number and connect to the other fax machine. It says sending, after about
Line noise is one of the common causes for fax problems. You might want to have your line checked for any noise.
Also, you can try to lower down the fax send speed. To do that, on the control panel of your printer, press on Setup > Fax Setup > Dialing and Sending > Max Send Speed > 9600.
Nov 30, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
Can no longer send/receive faxes since switching to digital phone
hi
fax does not work on digital line it only works on analog line........if u want our technician expert then contact us athttp://tinyurl.com/ldnuy2
Jun 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
I cant seem to send a fax
Check the phone line with a regular phone.
Jan 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cannot fax
Is thi sin an office?
Are you using a direct outside line or is it an office extension?
Your office extension may have restrictions on it and you would need to remove those.
I would confrim the numbers are fax numbers and that that line is ok by:
  • Dialing those fax numbers from a working phone line other than the fax machine
  • Unplug the fax and plug in a regular phone in the same line and see if you can dial out and then try those fax numbers again.
If the numbers work from a normal phone but not the fax line, then I would check that line for restrictions.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Outgoing Fax on my HP Officejet 6210 All-In-One
The fax machine needs to hear a dial tone first to send a fax. If you have no fax number, what working phone number are you using?
Jan 23, 2018 | HP OfficeJet 6210 All-In-One InkJet...
FAX ANSWERS AND DIALS, BUT DOESNT FININSH THE JOB
have you try rebooting the fax or even unstall the software and then reinstall software.
May 21, 2008 | Brother MFC-8440 All-In-One Laser Printer
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
118 people viewed this question
k24674
jasbo
jasbo
