Question about AOC CT720G 17" CRT Monitor
Crt monitor video chroma processing
I think my monitor has a loose parts in video chroma processing parts. can you kindly advice me what part will i check?
  • 348 Answers
First you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Posted on Oct 30, 2008
My picture only shows black and white on my pioneer elite once i unpluhgged it fron the cable box. the box isn't broken and the color on the tv works on the menu if i disconnect the cable
Check the color level for that input. While monitoring the cable box go to the video part of the setup menu. Make sure the chroma or color is up to its normal setting.
Some TV sets have independent video settings for each input. This way each input can be separately set up.
There is a possibility something went defective thus causing the chroma processing to not work, but this rare. The menus showing in color are from a different built in circuit than the one that decoded and processes the program video.
Oct 02, 2014 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Green colour missing
Hey check crt board for loose soldering ,check main board where the wires lead to the crt board ,check video/chroma circuit for loose soldering
Dec 12, 2013 | Sansui DTV2760 27" TV
When I start it the picture is green
loose contact at the chroma board, it was a small board hook up at the picture tube. tried to re soldered component parts here usually drive transistor for color.
Oct 27, 2012 | Philips Brilliance 107 17 in. CRT Monitor
COLOR PROBLEM
your tv need a reheat.reheat from video chroma to crt board
Oct 16, 2007 | JVC AV-27530 27" TV
My television set has no color.
it is due to problem in chroma section in your tv.
plz check as given
  • loose contact in chroma processor section
  • connector loose in chroma
  • loose or print cut near crystal
  • loose contact near color control related ckt.
  • set not tuned properly. re tune it
  • weak input signal from source.
  • chroma processor pin loose.
  • chroma input print loose.
  • chroma processor might be defective.
  • hope this will help.
  • good luck
Oct 16, 2007 | Philips 32PT5441/37 32" TV
No video
from voltage given by you states that rgb output voltage is more than normal & drive is only .2 volt which is abnormal means signal is not coming from chroma ic. so check for loose connection in chroma ic or connector loose. same time your drive voltage abnormal is due to signal not coming so no voltage drop & more voltage. also check for crt base loose. hope this will help. good luck.
Oct 01, 2007 | Televison & Video
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
Zenith big screen
sound is ok means power supply is ok. as there is no picture there is a problem in video or luminance section. 1 check chroma ic supply 2 check signal line to video section 3 loose contact in video section 4 crt base loose 5 crt supply 6 no supply to g2 7loose contact in brighness line
Sep 16, 2007 | Televison & Video
KV-32XBR250 Has about twenty Horizontal, Light Red bars aternating
your problem is called retrace lines it is due to 1 supply to red out put is absent 2 problem in red video output 3 loose contact in red output ckt 4 connector loose 5 crt base loose 6 circuit from red output of chroma ic to red video input 7 chroma ic defective regards
Sep 11, 2007 | Sony KV-32XBR250 TV
Shuts down
it is due to problem in red cideo section. solution 1 supply to red video output& output itself 2 crt base loose 3 connector loose 4 red video sigal line from chroma ic to red cathode of crt. 2 red
Nov 13, 2006 | RCA 27V520T 27" TV
AOC CT720G 17" CRT Monitor Logo
142 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
