Need an instruction manual for an AWA DP602 5.1 dvd player for connection to a fujitsu plasma screen. will i be able to get TV channels programmed into the DVD?
Dont know how to set up for TV channel viewing on my plasma screen
  • 1 more comment
  • twin1165 Sep 18, 2008
    Thanks I will try this and get back to you if I have any problem
  • twin1165 Sep 19, 2008
    Do I need the cord with the blue, green and black plugs because the display unit is not colour coded. What is the best configuration to use or the DVD player. I was able to get the screen to display the channels when i plugged in a really old video player but it was a luke. I am very confused.
  • twin1165 Sep 23, 2008
    the tv is a fujitsu 42"plasma screen and the DVD is AWA DP 602 5.1
  • 374 Answers
IF YOU HAVE CONNECTED THE DVD PLAYER VIA COMPOSITE, COMPONENT, OR HDMI CABLES YOU WILL NEED TO USE THE REMOTE FOR THE TV AND PRESS THE SOURCE OR INPUT BUTTON TO CYCLE THROUGH THE INPUTS UNTIL YOU FIND THE ONE THAT YOU CONNECTED THE DVD TO. IF YOUR REMOTE DOES NOT HAVE THESE BUTTONS YOU CAN GO INTO THE MENU SCREEN OF THE TV AND PERFORM THE SAME THING USING THE MENU CHOICES.
HOPE THIS HELPS YOU. IF MORE ASSISTANCE IS NEEDED POST A COMMENT TO THIS SOLUTION AND I WILL TRY AGAIN.
Posted on Sep 15, 2008
  • Jim Franks Sep 22, 2008
    Can you tell me the brand and model of the dvd and tv so I might give you a more precise solution?
  • Jim Franks Sep 23, 2008
    I wish I had the exact answer but the model tv you have is very vague on their array settings so I am going to give it my best shot. You may eventually have to try trial and error obviously. Sorry I could not be of more help but below is a diagram with how I would attempt the connection.
Screen is in undefined mode
Something like that might happen if you've selected a "zoomed in" setting and it only applies to HD channels versus classic 4:3 channels and you're going through different formats.
I do not know the settings on this particular TV by heart, but I've early HDTV releases struggle with that.
The other alternative is a bad main board.
I'd go to settings first and I'd also check if the problem is not showing only on certain channels (mostly HD versus classic format).
Mar 07, 2014 | Sanyo DP50747 50 in. Plasma TV
Why is channel manager option grayed out?
Channel manager may not be an available option for over-the-air viewing
Jan 27, 2014 | Hitachi 42 in. Plasma TV
I have a 46 inch Toshiba plasma tv. It is having a problem where the picture does not come up as soon as I turn on the TV. After about 20 minutes of warming up, the picture appears as normal but during the...
This tv is not repairable only can be replaced the Plasma screen itself.Not woth it,replacing the plasma screen,will cost the same as a new tv.This problems,u discribing is the Plasma screen itself sure comming to used and ages.Not any electronic boards componnent.Because the floorscents Plasma gas u seeing on the screen itself forming and lighting up the Plasma screen itself.
Dec 31, 2010 | Toshiba 42HPX95 42 in. Plasma Television
Gray bars while full screen viewing my Broksonic CCVG-4500 42 in
hi, i have a broksonic model ccv-4500 , these is a monitor or tv because i cant founder the digital cable imput. thanks.
Apr 25, 2010 | Broksonic CCVG4200 42 in. Plasma TV
Plasma TV moving black and white lines
This is a result of poor conversion of a SD signal on a HD channel.  Go into your settings and adjust the h/v settings to move the line off the screen.  You can do this with a combination of v-position or vsize.
Jan 26, 2009 | Vizio GV42L 42 in. LCD Television
Panasonic plasma TV has a black screen after disconnecting Dish TV
proably not tied in tv nomore dish will take over that prot if u got dish hd u get locakls form dish free in hd dont need attc nomore
Oct 10, 2008 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
LG 42in plasma - Green dots on HDMI channel
The diffusion is slightly out of adjusment. This timing adjustment is difficult and on a single scan LG plasma the proper operation requires voltage settings first, then a scope to finalize the adjustment. I have good luck with this alignment by eye but have had alot of practice. This will require taking the back off and a person with the technical background to set this alignment properly. Sorry no easy fix.
Feb 18, 2008 | LG 42LC2D 42 in. LCD HDTV
Lines across screen when using View On Demand channels
Could be a couple of things causing this.
1) Obvious, but I assume that you subscribe to these services, because otherwise it could be the encryption.
2) Make sure that you have the set-top box connected directly to the TV, and not through an external recorder (VCR, DVD etc)
This would be a problem if the services were copy protected in the same way DVDs are.
You could also check the settings on the set-topbox. Make sure the video output is set to RGB.
Aug 05, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
SVA plasma tv-model# HD4208T
you can get a manual for your tv at wwww.partstore.com that will guide through the setting up of your tv,good luck.
Mar 23, 2007 | SVA-USA HD4208TIIIBU 42 in. HD-Ready...
Televison & Video Logo
648 people viewed this question
Top Televison & Video Experts
