Question about Fisher Paykel Eco IWL16
Water keeps running through washing machine(simpson 36s605). have checked pump not blocked
  • Peggy Love Jan 02, 2009
    Water just keeps running into washer. It keeps running until the hot water heater gets low and then pumps the rusty water into the washer. It never fills enough to start the wash cycle.
    Scholar:
  • 106 Answers
At what height is your exit hose. It should be approximately 3 feet up from the ground and then into the drain. This is rule one for all washers, it cannot be at floor level - your water will just flow out.
Posted on Mar 15, 2009
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
I have a simpson washing machine that doesnt drain after wash what could be wrong
water pump or water pump solenoid
if they check out ..faulty timer
to drain water out
have to put the drain hose on the ground out the door
or towels and buckets
Sep 17, 2016 | Simpson Esprit 750 Top Load 7.5kg
Simpson front load washing Machine ..Coming up with error code "E10"
E10 relates to inlet water supply not being adequate. Please check kinked inlet hoses, inlet water filter blocked, insufficient or no water is getting is getting to the machine.
Jul 22, 2016 | Simpson Washing Machines
Water keeps running & overflows
The machine has a cut off inside that should cut supply when enough has entered so cut off or sensor fault try run it empty see if its actally overfilling as the pump should remove excess i may be blocked
Apr 10, 2016 | Simpson Esprit 750 Top Load 7.5kg
My Simpson eziset 950 keeps coming up with error HC.
No water flowing in to machine. Check taps are fully open & filters on end of hoses are clean & not blocked. If all good then you probably have a faulty inlet valve.
Dec 14, 2015 | Simpson Washing Machines
My simpson eziloader machine won't start - when I press the start button it clunks a couple of times then nothing - water won't enter have checked the inlet pipes
sounds like blocked pump or door latch sensor/switch more likely pump blocked.thats normally first to activate in wash cycle.if unsure seek help to locate and check.it ll be either accessable from bottom front of machine or you may need to tip it up as it ll be at bottom of machine.unplug first,and if you pull pipes off pump to access there will be some water.hold waste pipe as low as itll go to release any water left in machine
Feb 21, 2015 | Simpson Washing Machines
Simpson EziSet 750 washing machine won't drain the water. please help me.
Lid switch faulty, pump blocked, outlet filter blocked (If fitted), pump needs replacing.
Dec 19, 2013 | Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Simpson eziset 450
It sounds like the drum is so away from level that water is not flowing to the drain line, hence the pump running out of water. I would make sure the machine is level and the drum is resting level if it's the type that pivots around inside the machine. Failing that I would open up the machine and check the hoses to make sure they're not blocked. I would also check the drain hose to make sure it's not placed too high or in a way that will obstruct water flow.
Oct 19, 2009 | Washing Machines
Fisher Paykel Eco IWL16 Logo
277 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
levittg
Level 1 Expert
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
