Question about HP Computers & Internet
Would'nt start computer broken
  • 75 Answers
If its not powering up..check all the connection specially power cable
Posted on Sep 15, 2008
Mower was running until it stop and would'nt start found out the one of the push rod was broke replaced it and now i can't get to start and its flowing out the plug
A broken pushrod can indicate an engine with out of sync valve timing. It may be that a piston slapped an open valve snapping the pushrod...neither one is good, you may need to tear this one down.
Sep 19, 2012 | Garden
Dewalt dw297 impact wrench does'nt work at all. the cables does'nt seem broken, so don't know what to look for.
A good place to start with Dewalt tools is the switch. Take the front off the handle and pull the switch out far enough to test the posts on the back. Plug the cord in and check for voltage where the cord attaches to the switch. No voltage, bad cord, replace the cord. If you have voltage, the cord is good. With some help, hold the switch on and check for current on the motor side of the switch. If no voltage, replace the switch. If there is voltage there, you are going to have to check the brushes, armature and/or field for continuity or shorts.
Jun 27, 2012 | Dewalt DW297 3/4-Inch Impact Wrench
Bought mower used has nt been started in a while .when try the manual pull start the string does nt retract
sounds like the impeller on the underside of the starter mech is broken
Mar 06, 2011 | Garden
I have a 6 yr old Pentair Minimax NT heater that just started leaking water. Is it worth it to repair it, or should I just buy a new one?
Buy a new one. I spent $650 beginning of season to replace the manifold that was leaking and now it is broken. Again. Had since new and every year it breaks, sometimes twice. 6 years of dealing with this piece of junk.
Sep 14, 2010 | Pentair Minimax NT Heater
2001 Ford Ranger cranks but doesn't start periodically
If it has a distributor it is possible that the reluctor / stator has a broken wire. preventing the computer from firing the engine. This can be intermitant and would require the removal of the distributor. If the engine has a crank shaft sensor then this may be a possible place for a broken wire or bad connection. Location for these can be on the harmonic damper at the from=nt of the engine or located at or near the flywheel......
Feb 14, 2010 | 2001 Ford Ranger Regular Cab
Out of range H and V after AFTER i USED PARAOGIC DRIVER CURE.
I opened gotomyPC from my laptop and was able to remote access the problem computer.w nt into control panel and reset the computer back to a previous date. it worked
May 12, 2009 | Chi Mei Corporation CT522A 15" LCD Monitor
Lode needed dlls for kernel
Use the ERD disk and repair the installation. Choose to replace all files, and then replace only the Hal.dll and Ntoskrnl.exe files.
If you can start another installation of Windows NT on the same computer, you can expand the correct Hal.dll and Ntoskrnl.exe files from the Windows NT CD-ROM. To do so, follow these steps:
  1. Boot to the working version of Windows NT.
  2. Start a command prompt.
  3. Change to the CD-ROM drive.
  4. Change to the appropriate folder on the CD-ROM (for example, I386 for Intel-based computers).
  5. Type expand hal.dl_ <systemroot>\system32 where <systemroot> is the path of the non-functioning Windows NT folder.
  6. Type expand ntoskrnl.ex_ <systemroot>\system32.
  7. Restart the computer into the other Windows NT installation.
Mar 27, 2009 | Microsoft Windows XP Professional
How to disable start menu from desktop
tell me exactly what you want to use this for.
Is it for a internet cafe? I will then be able to give you the best solution.
Using group policy you can take out options within the start menu but cannot remove it totally.
If you want your computer to only start up internet explorer as soon as you turn the computer on, then you will need to play around with the system registry to do that, in order to disable explorer from lunching.
Go to Start/Run/Regedit and navigate to this key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Download readystate from microsoft and play around with that, a very cool tool.
Jun 26, 2008 | Compaq Presario 5000 PC Desktop
My did`nt start
I know what it is: It is broken
Dec 04, 2007 | Fuji FinePix S3100 Digital Camera
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
