Question about Olympus Cameras
I have an olympus 500 and im not sure if it takes a charger are an battery??
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
There is sp-500 which takes AA, the e-500 and stylus 500 uses lithium ion batteries...which do you have
Posted on Sep 15, 2008
How to recharge battery
Take the battery out of the camera, put it into the supplied LI-40C battery charger or a compatible, and plug the charger into a power outlet. If you need a battery charger, you can order a compatible charger from
http://www.overstock.com/Electronics/3-piece-Battery-Charger-for-Olympus-FE-220-FE-230-240-LI-42B/6081946/product.html
Jul 30, 2011 | Olympus FE-280 Digital Camera
Need ordering information for a replacement battery for your E-500 Battery info I have is Model PS-BLM1 Li-ion barrety pac BLM!. Please advise, price, availibility, and price plus how to order...
Olympus no longer lists the BLM1 battery, but they do have the newer BLM5 battery for the E-500. The BLM5 requires a different charger, however. Full information (including price and ordering) is available on their web site at
http://www.olympusamerica.com/cpg_section/cpg_support_accessories.asp?id=1192&ct=2
Jun 02, 2011 | Olympus EVOLT E-500 Digital Camera
Camera wont turn on
1. Are you sure the battery is fully charged?
You can charge the battery by connecting the Olympus USB cable to the camera and computer.
Or using the delivered wall charger. When charging the orange LED on the camera should light.
When fully charged, the LED is off.
2. If this does not help you, check if your battery is well seated in the camera.
3. Check if the battery is faulty by replacing it by another one.
See users manual page 9, 12 and 53
May 25, 2011 | Olympus SP-500 UZ Digital Camera
My Olympus charger for the LI 10B battery does not light and charge the battery. Can the charger be fixed or do I need to buy a new one? By the way, my camera is Olympus C5000. Thank you.
I would say that you need a new charger. Standard chargers that come with digital cameras will eventually deteriorate depending on how often you use it. However, it could also be a battery issue, as batteries eventually will die even if they are rechargeable. I would try the charger with a different battery and see if it works, and if not, then you will know that the problem is with the charger.
May 07, 2011 | Olympus Battery Li-10B Li-12B (D6102003)...
How do I charge my Olympus camera? I've gone over the instructions a dozen times, and I just can't get it to work. Please help....
You must use the F-2AC battery charger along with the provided USB cable to charge the battery in the camera. Make sure the cable is inserted fully into the charger and the camera, it can take some force.
To charge the battery outside the camera use the LI-41C battery charger.
Mar 01, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
Do you guys make a wall charger which has a cord to jus plug in to my camera vs take batteries out every 45 minutes to charge again
You need to contact Olympus or buy one from a site such as Ebay. Search on Ebay for your camera name and model. They vary, but should be reasonable.
If you are needing to charge the batteries so often, then either the charger is not good or the batteries, one or all are weak or defective.
Make sure that the menus are set for the kind of batteries you are using.
Nov 14, 2009 | Olympus Camedia D-435 Digital Camera
Battery charger won't charge
I'm sorry to say I don't know much about Olympus digital cameras, I've never had one on the bench.
I would take your camera and charger to a shop that sells Olympus batteries try a different battery first, this way you can try it out before you buy and make sure the camera and charger are working ok...
The battery is a Li-Ion, when these get flattened too far they shut down and will refuse to charge, they can sometimes be recovered by using a power supply to lift them but you must be very careful (use a 300ma wall wart at just over the rated voltage of the battery for 10 mins then put it back in the charger) as they can catch fire if over charged, shorted or connected backwards also if its been so flat it refuses to charge its certainly past its best and should be replaced as its likely it will let you down again.
On the other hand it could be the charger, so best to try and check out both before buying anything.
If it happened very suddenly and the battery was still able to run the camera for quite a while I would think a charger problem is more likely, if the battery has been taking less time to charge recently and lasting shorter times its more likely the battery..
Having said that the protection circuits can shut down a seemingly good battery for other reasons.
If you find its the charger third party (non Olimpus) chargers are available quite cheaply on ebay as are batteries
Best of luck
Jun 14, 2008 | Cameras
Battery charger for Olympus E-500 camera
dear cienkusmike,
This charger should work to charge the battery that came with the olympus E-500.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 08, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus µ Digital 500 flash is not working. Flash indicator keeps on blinking. But when the flash is off, the camera can take pictures. I also notice that the battery and memory card get hot when the...
This suggests the flash capacitor has malfunctioned
Check Olympus for a warranty replacement or repair cost- according to age of camera. If it is an older model a new camera may be best bet
Dec 20, 2007 | Olympus ? Stylus 500 Digital Camera
Battery life expectancy
The battery life of AA alkaline batteries varies according to the manufacturer and power rating. Alkaline batteries can provide up to 100 shots with typical usage. Olympus NiMH batteries (B-01 4PE) provide approximately 250 shots per charge and can be recharged 300 to 500 times. Olympus recommends the use of CR-3V batteries or NiMH batteries. Olympus sells an NiMH Battery set which includes a charger and set of 4-NiMH batteries. You can purchase this through Olympus dealers or through the Olympus Emporium (www.olympusamerica.com/store).
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Cameras Logo
42 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
