Question about Canon EOS 400D / Rebel XTi Digital Camera
Canon 400d Hi, I was using my camera with a Canon speedlite 530 mk2 flash when it just died,(camera not flash) replaced battery, removed battery, recharged battry, tried the on/off switch, left it for a couple of days etc etc etc. The camera is basically............dead. Any ideas. Best regards John
    Novelist:
  • 164 Answers
Such symptom indicate a malfunction on the DC/DC voltage converter circuitry, and the camera has two of them located in different boards.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you hav the options of pay for its repair, or do it yourself if you are willing tgo open it and perform some basic diagnostics of the failure. You will needtools to do it, which includes the usage of a soldering iron.
Best regards,
Posted on Jul 23, 2009
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Flash does not output correct amount of light resulting in under exposure
What kind of flash is it Brian? Is the flash set to manual or E-TTL?
Jun 23, 2013 | Canon SPEEDLITE 580EX TTL Flash
Canon speedlite 430 EZ does not match with canon 400 D digital camera how to use the same flash with 400 D.
You can't. The metering systems are incompatable. You must use the EX range with the 400D, such as 430EX or 580EX (versions I or II)
Feb 25, 2009 | Canon EOS 400D Digital Camera
My camera is a Canon 400D. I put an external flash on it just few moments ago (canon speedlite 580EXII) and the flash wouldn't go off when i took pictures. So i took the flash off, but now the flash on the...
Hi Chrissy, I had observed the same problem - after an external flash had been removed from the camera, internal flash didn't pop up. Tried to look at the Google and finally found the solution. It helped me and could help you as well:
The usual reason is that the camera thinks that there's an external flash mounted on the hot shoe. Check the external flash detect switch. It's located under the right side of the shoe (there is a metalic piece which is kind of "elastic". Just try to push it and release several times, may be put the screwdriver softly under it and out... It helped me. Here is the picture of location of the detector.
Jan 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Speedlite 430EX zoom issue
You're gonna kick yourself, but here goes, you know that clear plastic wide beam shield on the front, make sure it's fully inserted or else the auto zoom won't work while it's in use, (or the flash thinks it's in use)
Aug 07, 2008 | Canon Speedlite 430EX TTL Flash
Won't Work As Slave With Canon EOS 400D
Speedlites with the suffix "EZ" are never compatible with the digital EOS line-up. All models that do work are named "EX" (420, 430, 550, 580EX et al.)
Apr 03, 2008 | Canon Speedlite 540EZ TTL Flash
Speedlite 540EZ and EOS 400D
540EZ will not work on digital Canons in auto reading mode. It will only work on manual flash settings.
Mar 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon 400D
Use a card writer and copy your pictures to the CF card on the computer.
Jan 07, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Xti and Speedlite 200E
The only way to solve the problem I see is to turn the flash into non-TTL one. It can be easy done by opening four screws at the connector side of the flash, unsoldering or cutting the BROWN line and closing the connector back. The AF assist led will work.
That I did on my 200E with Canon 400D camera and all works file.
Enjoy!
Jan 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera Logo
62 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
