Question about Panasonic NN-S254BF Microwave Oven
Faulty magnetron re:NN-T704QFQPQ Panasonic microwave We have had the above microwave model for just under a year now (this is our second one in 12 months. The first one was faulty too and had to be replaced). The microwave doesn't always heat our baby's bottle properly and recently developed an intermittent habit of "sparking" and "crackling" from the magnetron. Even though it is still under warranty, the shop we purchased it from have looked at it and told us that the magnetron is faulty because we must have run the microwave without anything in it!!?? They say it is the only way the magnetron could have been damaged?? However, we haven't run the microwave in this way, either deliberately or inadvertently......would you know if there could be any other reasons the magnetron could have got damaged? Cheers
  • Panasonic Master
  • 9,098 Answers
I would contact Panasonic about this and tell them your story.
That is one way it can happen, but things just fail, too.
Otherwise, we servicers would not be in business.
You do need to be sure there is no grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
You can call Panasonic at 1-800-211-7262 or visit here.
Posted on Sep 15, 2008
Panasonic microwave combi oven model nn a772 sbbpq. I set the microwave for 12 minutes but forgot to put the meal in. It now works for a few seconds then stops. Any help would be appreciated
A thermal cutout on many ovens is black with two terminals. It's usually held in place by a bracket and one or two screws. Many ovens now use a thermistor instead of a cutout on the magnetron.
Based on the symptoms you describe, it seems unlikely either would be the cause of the problem. If a microwave is run empty, the magnetron will draw excessive current. The excessive current can take out the magnetron, high voltage rectifier, high voltage capacitor, fuse, or a few other components. If this is an inverter oven, check for a fault code of "H98" or something similar. That would indicate a problem with the inverter board, or something else in the high voltage circuit.
Feb 09, 2017 | Panasonic Microwave Ovens
Where is the thermal switch located
If your model is NN-P295, then the service manual is here.
You can order Panasonic parts from
Encompass here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Most microwaves have a thermal cutout or thermostat on the magnetron, on the top of the cooking cavity, and often on the floor of the oven or above the bottom cover.
Jul 13, 2011 | Panasonic NN-P295SF Microwave Oven
Panasonic NN-P794 NO HEAT this thing will run for 18 seconds only, then shuts off. Everything else works fine. Is it worth fixing?
Have you unplugged it and allowed it to reset itself? Sometimes the wire comes undone to the magnetron, that could be the answer. It is is bad (magnetron) it could be melted and dangerous to use. A bad magnetron is too expensive to repair. Also, another possiblity is the metalic shield may need fixed or replaced (about $20.00). If it's under warranty, take it back.
Jan 10, 2011 | Panasonic NN-P794SF Microwave Oven
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Sep 30, 2010 | Panasonic NN-T695SF Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Model # NN-T793/T993
My first guess would be to checvk the venealation fan
Mar 31, 2008 | Panasonic NN-T993SF Microwave Oven
Turning off before finishing time time cycle
I have just had this problem where the oven will only run for 5 seconds and then turns off model #NNS561. Cant find any solution.
Jan 19, 2008 | Panasonic NN-S950BA Microwave Oven
Panasonic NN-S254BF Microwave Oven Logo
202 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
