Question about LG WFT1071TP Top Load Washer
Wf-s5607ppt faulty Wen I switch on the machine It flashes all the water level lights and beeps. How can I fix this?
4 Suggested Answers
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Posted on Sep 09, 2009
SOURCE: my lg fuzzy logic wf s6607tc water level indicator
my daughter and myself give the lid cover a very hard knock and suddenly the washing machine works again.
Posted on Jan 11, 2010
  • 343 Answers
SOURCE: WF-F7061DN NO WATER FLOW IN TO THE MACHINE, UPTO
Water inlet valves tend to fail from time to time. This the most likely source of your problem..........Nomess
Posted on Apr 18, 2010
Beginning of cold cycle water temp lights flash and beep machine stops. Sometimes when water level set to high only half fills ??
SOUNDS LIKE U MAY HAVE AN ISSUE WITH EITHER UR WATER PRESSURE SWITCH OR UR WATER INLET VALVE/
U FAILED TO MENTION IF IT WORKS OK IN HOT WATER? IF SO THEN CHECK UR INLET VALVE OUT THE COILS MAY HAVE GONE BAD ON THE COLD WATER
May 16, 2015 | Washing Machines
WF-F7061DN washing machine water level lights flashes
Are you overloading the machine? If you run the machine without anything inside and this happens, check the motor or belt.
Jan 14, 2014 | LG Washing Machines
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
Error message - PE.... on lg intello washer. my washer is full of clothes and water.it won`t get to the cycle for rinsing .I press on auto-off , then start-pause . the light for water-level does not go on...
Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
Nov 21, 2017 | Washing Machines
Dear Mr/Ms, I think my ecosave washing machine has some mis-functions. Whenver what process has been done, symptoms are the same. The symptoms are the followings . . . . - blinking error LED light:...
The error came from an electronic control, the damage usually occurs in the data memory. under normal circumstances should have after finishing washing or spin process, washing machine will turn off automatically, indicated by the beep sound and flashing lights first. if you quite understand you just need to fix the electronic control block only, reset IC memory or the easiest way is to unplug all cables (socket) connected to electronic control, turn on the washing machine and then power off and reattach all the cables socket into place. particularly note the socket cable of  water level sensors and unbalance switches. electronic control block is usually coated with rubber glue. but I often fix it without having to replace the whole (one block / set electronic controls). good luck
Aug 07, 2010 | Washing Machines
Fisher & paykel - SPIN light keeps flashing and machine beeps
could be a faulty off load switch
running off balance
machine not level
depends how old the machine is then
if none of those
worn machine motor or internals
might the the circuit board
Apr 16, 2017 | Fisher Paykel EcoSmart GWL15
Washing machine not starting
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 03, 2009 | Washing Machines
LG WFT1071TP Top Load Washer Logo
70 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
