Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi Projcection TV
My tv wont turn on , only clicks you mentioned stand by relays may need replacing, any idea of cost, I want to know if it would be worth it.
Ps I also plauy the accordion, Iorio accorgan
  • 979 Answers
If the High Voltage section is working Ok, the relay Could be the culprit.. The cost is negligible, about 40 bucks. The standby voltage needs to be verified as correct before the H.V can switch on. If the HV section is bad, you could be looking at about 150 to 200 bucks to get it back up again.
What model Accorgan do you have? Iorio imported many units from other MFGRS over the past number of years. The last model out was a "J" series, and was manufactured by SEM in Italy, with sub assemblies being built in France, Russia, and Austria. Early models were the "G", "H", and "I" series being built back in the 60's, 70's, and 80's, respectively. Those models were manufactured by Elkavox..accordianman
Posted on Sep 15, 2008
I have a 1995 honda accord lx. I have fuel pressure, I have changed the main relay, I cant get it to start. I also have spark. anybody out there have any idea what might be the problem.
you may have fuel pressure at the rail, but how do you know if the fuel injectors are opening?
This needs to go onto a scanner to see what is wrong.
The cars electronics may be preventing the car from starting camshaft sensor signal is missing so the ecu would not know when to start or in what order. Its a safety function really.
Get it scanned, check the codes...stop guessing (that costs loads of money) and just replace the faulty part...or reset the ecu.
ps.....have you tried removing the battery neg cable for 20min?
Always worth a try.
Ps....dont leave your keys in the car when you do this !!
Apr 15, 2014 | Cars & Trucks
My tv screen went completely black
If its worth fixing depends on age of set and what it cost.
The place to begin is someone needs to open the set and check a few things------the click is a mechanical relay coming on and likely going right back off.
The problem could be minor or major.
You might want to begin by calling local shops and see what they charge for an estimate of repairing----should tell you if you want to proceed or move on and replace this set.
Mar 16, 2012 | Sanyo HT32546 TV
I have a Hitachi Tv Model # 5oux14bc I can hear clicking sound when i turn the power button and sometimes the red light will come on and then go off What can be the problem>
The clicking sound you are hearing is due to the relays turning off the set because a protection fault has occured(usually over voltage due to failed voltage regulators). A component level repair is possible more often than not but if you want to do it yourself then you should know how to use a multimeter and soldering gun.
PS: It is not a good idea to mess with High Voltage appliances unless you are highly skilled in electronics . The set holds lethal voltages for several days after its turned off and unplugged(the voltages are present in the capacitors). Your life and limb are worth much more than this.
Oct 30, 2010 | Televison & Video
My PS-42C91H/PS-42C91 fell and the screen broke Is it possible to get it replaced? and how much does it cost
No,not worth as a whole tv anymore,because by replacing the Plasma screen panel,will cost the same as a new tv.Because the screen panels are limited produced by the tvs corporations.The tv now olny worth as a salvages for electronic board for parts only now.
Sep 20, 2010 | Samsung PS42C91HDX 42 in. Plasma TV
42 philips plasma tv
my tv wont turn on makes clicking noise and there is a green light in the back flickering
Jul 11, 2010 | Philips Magnavox 42MF521D/37 Television
42" LG 42LC2D HDTV Will not turn on
Hi, sounds like a power supply problem, most likely needs capacitors replaced, costs about £5 to do it yourself, and a fortune in the repair shop, easy enough if your handy or know someone who is,its worth a try,it'll be going in the bin anyway, cam
Jul 13, 2009 | LG 42LC2D 42 in. LCD HDTV
Faulty parts on PS board , bad press for Samsung
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced.
Dec 31, 2008 | Televison & Video
Tv wont turn on -- stand by light just keeps blinking
This is very common problem for sony. Blinking light is power supply problem need to replace two voltage reulators in supply and caps and sometime horz output.
Sometimes if you adjust screen voltage adustment on flyback just slightly it will fix it.
cost if ps is 225.00
screen is 95.00
Thanks doctor video
May 17, 2008 | Sony KV-35S45 35" TV
Astar Plasma
I had the same problem... Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Jan 13, 2008 | Astar LTV-3001 TV
Hitachi 53UDX10B 53" Rear Projection Television Logo
168 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
