Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Flashing lights I have a hotpoint dwf40p ser no ls12-ev03 it pumps fills then the wash light and the drying lights flash and dishwasher stops with no further progress
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
  • 3 Answers
SOURCE: Hotpoint FDW60 dishwasher - flashing lights
check the filter.
Posted on Jun 06, 2008
  • 93 Answers
SOURCE: Premature drain on Hotpoint HDA 3400 dishwasher
hello my name is gilles the problem you have their is something stuck in your drain valve causing the valve to stay open remove the valve clean out reintall every thing should be fine thanks
Posted on Mar 15, 2009
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: dishwasher element and thermostat
Did anyone get this sorted, mines doing the same. It stops at position 12, no power at the heater, so it stalls. I have replaced the dual thermostats, and the heater element is returning 25ohms resistance.
Its doing my head in!
Posted on Dec 04, 2009
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
Can anyone tell me about the washing cycle symbols on my Ariston LS12.EV03. It came with the apartment with no manuals...
Best I could do for instructions in English: http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Ariston/Dishwashers/AF350X_034628gb.pdf
Here is a site with a lot of manuals for Ariston products, with other brand names: http://www.manuals.club/results_alpha.php?ctext=ARISTON+DISHWASHER+LS12-EVO3
Mar 05, 2015 | Dishwashers
FDM 554 - Water has filled but, won't start. eventually get flashing wash and drying lights.
Are you please able to confirm this combination of flashing lights is not shown as an error condition in the dishwasher manual under the trouble shooting section.
See this site if you do not have access to instruction manual.
Mar 17, 2011 | Hotpoint Dishwashers
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Our ls12 ev03 dishwasher won't turn on, every time it is switched on it says'I'm still drying' with it's flashing light evn when it has not been programmed to do anything
It could be that it was opened before it had finished its last cycle. When you switch it on again, it wants to finish. You could either leave it on until the drying light goes off, or force it to finish the cycle. I'm not familiar with that model, but on mine I have a Stop option on the dial. On the machine I had before, I had to press two buttons together to force the end of cycle. Worth a try. Good luck.
Jan 06, 2009 | Dishwashers
BF162 DISHWASHER HOTPOINT
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Feb 09, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
35 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
