Hi, I have an Acer Aspire 5920G. My problem is when the laptop is switched on it sounds like it's booting but the screen stays blank? Have you any idea what can cause this? Regards, Dan Pook (daniel.pook@arup.com)
  • 477 Answers
Hello
I think your graphics card or screen is broken on your Acer Aspire 5920G, one thing you can test is to connect at external monitor to your laptop. If you dont get any picture then its your graphic card broken, if you get picture it is your screen. also try to adjust the screen light.
Posted on Sep 15, 2008
Hi I'm using aspire 4738G . Well my laptop does turn on and shows acer in the screen and immediately turns blank out with white dash (-) On the top left of the screen. It never shows any progress afte
the white dash is a command cue and it is waiting for you to enter a command for the laptop to proceed
when you switch the laptop on , hold down the delete key until the bios screen appears
go to boot tab and check where the boot priority is
it should be first priority , hard drive
if not make it the first priority save yes and esc.and shut down , then reboot
Jul 07, 2017 | Acer Computers & Internet
Acer aspire 5920G- wont switch on. I can't hear
Hi Lenny,
not god news Im afraid, it sounds as though either your screen or your graphics chip are faulty. Help is at hand though, you could try connecting to an external monitor, but as your laptop is switching off, it is unlikely that this will work any better. You can remove the hard drive any install it into another machine, this should be straight forward, although if the machine in question does not have the corect connections then you will need a caddy. these are pretty cheap and plug into usb allowing access to the data on the drive. Hope this helps.
Feb 18, 2013 | Computers & Internet
Acer Aspire 5920g laptop My computer suddenly crashed during an update coming up with a blue screen. Since then I have tried to use the recovery disks. After successfully loading and showing "windows...
Hi
it may be worth trying this
power up and press the Alt+F10 as soon as possible and this may take you into the factory restore option
where you should have about 2 different options of recovery
just follow the on screen instructions
i hope you can get it sorted
Jun 23, 2011 | Acer Computers & Internet
On turning on ACER Aspire 5920G laptop the laptop goes through the process of booting up, ie all relevant LEDs on power come on. The screen does not load up with usual ACER whitescreen and comes up with...
Hi. Yes, it could be a failing LCD screen but I would suggest to check the ribbon that connects the LCD screen to mainboard and make sure that it is not damage and properly connected.
Aug 20, 2010 | Acer Aspire 5920-6727 Notebook
ACER 5920g needs to stay on when lid closed
Plug first you computer o rather laptop to your TV with the right cable then right click to your desktop. Select properties then select settings then in the display drop down box choose number two click apply and hit ok.
Then before you close the lid...hit FN (color blue key) then hit f5....it will switch to your LCD to your TV. Enjoy.
Jun 05, 2010 | Acer Aspire 5920-6335 Laptop
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
Acer Aspire 5920G BLANK SCREEN
First of all you have to determine if the problem is the GPU (graphics processing unit) or a possible bad connection on the inverter.
To check this you will need to plug an external monitor to the laptop and use the keyboard toggle to switch screens, usually its hold down Fn and press F6 or the F key with a monitor icon on it.
If the external monitor comes on then the problem maybe the inverter.
To check this remove the screen bezel (plastic screen surround). At the bottom of the screen you will see an elongated piece of circuit board with wires coming from either end covered by frosted plastic.
That is the inverter, check the connections on the inverter (both sides) and power the laptop up to check the display, to remove it gently pull the plugs from each end and remove the screw from the middle and pull the board away.
Look on the back of the inverter itself for a copper coil, if you re-solder the solder points around the coil you may find it works again as components that suffer from extreme heat the solder joints dry causing bad connections, re-floating the solder solves the problem in 90% of cases.
Good luck.
Sep 14, 2009 | Acer Computers & Internet
Acer Aspire 5920G startup issues
If unit is not booting you cannot use the system restore tool. And if you have not created back up disks .................
At least you did not have the machine long enough to really load it up so reloading it will not be so bad. However, ......
Maybe you picked up some computer clap? Using another machine download the malware bytes program onto a usb stick and then boot up your vista machine via the F 8 prompt (desktop + networking) during bootup.
Then when on simple desktop, insert usb stick and navigate to the file downloaded and run the app from there. Good luck!!!
Mar 23, 2017 | Acer Aspire 5920-6727 Notebook
Laptop Wont Boot
Does it sound like it's starting up at all? Is the problem that only the screen turns blank? You might have just disabled the standard output. Try pressing Fn (bottom left on the keyboard) and the F5 on the top a few times to see if the screen toggles back on. You might also try to run it without the battery, and on the battery only in case it's a faulty battery or power supply that causes the problem. If not, it sounds lsike a serious problem, so if there is any chance of the waranty still being valid I'd call acer support asap.
Jun 17, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
