Question about Magic Chef CMV1000B Microwave Oven
Sharp digital microwave oven is not heating
Lights on, turn table okey, only it is not heating...please help.
  • Magic Chef Master
  • 9,086 Answers
I would most suspect a shorted high voltage rectifier diode, a bad connection on the FA terminal of the magnetron, or a bad magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Posted on Sep 16, 2008
Sharp - Food not heating up but all is lit up and turn table turns
Hai my friend, if its not heating you must open it at the back and check your fuse on top for contuinity using amultimeter it must be on abuzzer and if its fine there is other fuse covered with normal black cover connected to the cspacitor also check it, if this two fuses are fine check your capacitor if its fine check your magnetron for contunuity of 0,2 ohms but normal if its not heating its fuse, thx
Sep 13, 2014 | Sharp R959SLMA 900 Watts Convection /...
Sharp R270SLM does not heat anything
magnetron has probably failed . only a good repair shop can assist you
Apr 16, 2012 | Sharp R-1480 Microwave Oven
Does not heat
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS..thank yuo for choosing fixya..
Jul 20, 2011 | Sharp R-930AK Convection/Microwave Oven
After I switch on the oven, the turn table rotates but no heat generated.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | Sharp R-230 Microwave Oven
My Sharp R-1870F microwave in our rv heats intermittantly and the turn table is stuck. Any advice?
Check the oven door if it locks up, the oven has an automatic feature that when it is not closed properly it won't initialize. Since it heats up intermittently I think the heating capabalities of the microwave is still good, and this problem might be just due to something that is preventing it to operate. which most likely the the locks of the door.
Jul 07, 2010 | Sharp R-1870 Convection/Microwave Oven
Had problem with Sharp R-520L. Microwave suddenly
One of the door switches is the problem. Open the casing, and you should find the schematic diagram. Find the switches, and test if you can. If you cannot - replace all of them except the monitor switch.
Nov 17, 2009 | Maytag MMC5000 Microwave Oven
My microwave does not heat anything. The touchpad, exahustfan, light works. The motor turns on and turn-table works for the number of mins specified but does not warm up the stuff. Please help!
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 25, 2009 | Whirlpool MH2155XP Microwave Oven
Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jan 13, 2009 | Sharp R-1850A Convection/Microwave Oven
Sharp microwave model #1872
Most likely the lower door interlock switch is bad. Cheap and pretty easy repair.
Martin Microwave Inc. sells the switches for around $5....
www.martinmicrowave.com
Oct 27, 2008 | Sharp R-1870 Convection/Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
151 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
