Question about Dishwashers
Dishwasher not washing correctly
This is a second attempt at some help...I think I need to provide more detail...My dishwasher is approx 2 years old, and since we moved in to the house, it does not wash or dry hot enough. It has fill hoses connected to both the hot and cold taps so I assume it is set up to use both...Don't dishwashers heat internally if the water isn't hot enough? THe prv owner swears it worked fine for her, could I have inadvertantly changed some setting, or could the element have gone - if this d.w. has such a thing. Please help before I have to spend dollars on repairs.
Miele MODEL G611sci plus-3, typ=HG02
SOURCE: Stays in wash cycle Whirlpool Dishwasher Du1050SS
my repairman contacted whirlpool about my washing machine staying on
wash.. to his surprise.. and mine.. and his co=workers.. this is the answer,
it worked.. and we have never heard this before.
In your original istallation booklet it tells you to let the dishwasher run til its complete
the first time you use it as it may rinse twice... my original installation man told me this also.
however.. if you suffer a "blip" in your electricity.. it could put the little dishwasher "brain"
out of whack.. it can run as long as 3 to 4 hours on wash to reset itself.. if you stop it
(like others have mentioned.. and which I did also).. it doesn't complete the reset and it
will attempt to do it the next time..
answer?.. just let it go once as unnerving as this is.. it works.. They did mention that
if it went to 5 hours.. call your repairman because you need a new mechanism.
karen in Dothan
Posted on Apr 03, 2009
  • 10865 Answers
SOURCE: kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Posted on Apr 19, 2009
gary1121
  • 332 Answers
SOURCE: IDL40 only washes in cold water now.
YES IT SOUNDS LIKE IT'S THE ELEMENT OR MAYBE A WIRE HAS COME OFF THE ELEMENT FROM VIBRATION,
Posted on May 29, 2009
  • 128 Answers
SOURCE: I have a G656 SCi Miele Dishwasher and the water
Probably the heater relay - do you have any fault codes?
Posted on Sep 23, 2009
  • 177 Answers
SOURCE: Miele dishwasher not heating
hi,
you would have to turn the unit on it's side and remove the bottom plate and check with a multi meter the resistance of the heating element to see if the heating element is defective. i doubt the dishwashing liquid caused a fault other than causing the unit to over sud and spill water into the base. You could remove the panel under the door and have a look and see if you have flooded the base. if you have a float switch in the base (white polystyrene disc and switch) this will stop the unit from working as well. dry up any water and try it again. hope this helps and don't use the dishwashing liquid in the unit.
Posted on Jan 22, 2010
Maytag Quiet Series 300 Dishwasher will only run part of wash cycle before tripping breaker?
I'm thinking dishwashers is installed in correctly. Too low causing an issue. Have a tech look at it.
Nov 17, 2013 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have model # FDB431LFCO My house is 2 years old.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Nov 20, 2009 | Frigidaire Dishwashers
4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Jul 26, 2009 | Bosch Dishwashers
I have a similar problem. But I will provide a little bit of history first. My dryer just doesn't get hot enough (approx 100 degrees just prior to the exhaust vent). Three years ago, I had the same...
If the gas cycles on and off I do not think the coils are a problem.  Sounds like the flame sensor is not working correctly.  The flame sensor keeps the gas valve open after the ignitor shuts off.  Then the temperature sensor shuts off the gas when temperature limit is reached.  When the dryer cools down the gas cycle starts again (usually much more than 30 seconds).
May 29, 2009 | Dryers
Seem to have an earth fault with a prima lpr 450 dishwasher runs for about 15 min then trips our electric.It did a few times from new (about 3 years old now) then stopped doing it, now does it nearly every...
Hello gcsounds,
If I understand your problem correctly, it appears that you have a ground fault ( or earth fault) that is causing your breaker to trip. I am assuming ( but don't know for sure ) that your dishwasher is hard wired into a junction box and that junction box is fed power from your circuit breaker panel. I am also assuming that the circuit breaker is either a Ground Fault Interupt ( GFI ) or standard type and that breaker is what you are saying is tripping with every wash cycle. There are some details that need to be filled in for me by you in order for me to fully understand your wiring scheme and suggest ways to resolve your problem. First off, can you provide details on how your dishwasher is wired ( as I suggested above or other) and secondly, what voltage are you running it at? If you are in the US then in all probability you are running your dishwasher at 120VAC @ 60 hz but if you aren't then please elaborate. Once I have that information, I may be able to assist diagnosing and resolving your problem.
Regards,
Rick
Nov 22, 2008 | Dishwashers
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Bosch dishwasher regularly floods
fault is with dishwasher. even if drain blocked, would not cause overfill.
possibly the pipe to sump from fill mechanism partially blocked
Jul 18, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
Top Dishwashers Experts
