Question about Philips Magnavox 32PS55S 32" TV
Tape plays for 5 seconds then stops and shuts off
We bought this tv and had it less than 6 months when it started doing this. Insert tape in vcr, it takes it, loads it, even begins to play it. You can see the picture but then just stops and shuts off. Also the Dvd player refuses to work unless the tape is parked in the player for what ever reason.. we've tried to watch the components inside to see whats going wrong and can't figure it out??
3 Suggested Answers
premtech
  • 934 Answers
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Posted on Jun 12, 2007
  • 65 Answers
SOURCE: The DVD side works great, but the VCR is not
This is a problem of the mechanism vcr. loock into the vcr because may be the kids put some objet inside vcr. To check also all the vcr belts.
Posted on Oct 06, 2010
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
VCR plays 15 seconds, TV shuts off. Same without tape inserted
Sounds like a typical Switched Mode Power Supply fault, or an internal thermal fault that is shutting down the power supply, over & over. Really you need to get it serviced. You need to get a firm "Quote" for repair, remember these days repair can often exceed replacement cost.
Feb 03, 2010 | Televison & Video
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
3-4 switch
1. Set tv to channel 4
2. insert a pre-recorded tape into vcr.
3.press play once to start playback.
4. after a few seconds press play on the vcr for 3 sec you will see a playback picture.
when a picture doesn't appear on the tv screen repeat step 4.
5. press stop to stop playback.
Mar 16, 2008 | Sanyo VWM-950 VHS VCR
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Setting up the chanel on the VCR
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
Stays on for 5 seconds, thinks it has a DVD or VHS tape in
I am afraid the set has a bad or broken tape transport, or better known as a bad tape carriage.
Jun 20, 2007 | Philips Magnavox 20MC4304 20 in....
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Philips Magnavox 32PS55S 32" TV Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
