Question about Dell OptiPlex GX520 PC Desktop
Dell optiplex 755 with yellow steady light on motherboard, loud beeps and black screen....HELP!
  • Dell Master
  • 7,482 Answers
Hi amyvolpert...
Try these solutions to your problem
Start your computer in the Safe Mode.
To start in Safe Mode.
Turn your computer on.
Keep tapping F1, F2 or F8 (depending on your computer) while the computer is starting up
When the computer starts select Safe Mode
1. Uninstall any softwear you may have put on the computer before the problem started.
2. Do a complete System Restore: Start>All Programs>Accessories>System Tools>System Restore.
This will bring your system back to a time before you installed the softwear or Microsoft installed drivers,etc.
Note: Just be sure to use a date in a darkened box, that is before your trouble start date.
When you have done the above, restart the computer and if your still having the problem, then the installed drivers,updates,softwear,etc might have
corrupted the Operating System.
If that happened then that means either repair or reinstall the operating system.
You will need to do the following:
1...Repairing the Operating System...
A...You will have to have the Operating Dics that came with the computer.
Note...If you do not have the disks that came with your computer or the ones you should have made when you first got your computer...then you will have to go to the manufacture's webpage and see if they have a recovery disk available for your computer, if they do not a recovery disks available then you can also try ebay to locate the recovery disks.
The original disks will have your product key number that came with the computer, you can also find it on the tower, or under the bottom of your laptop, or maybe the piece of paper that the CD orginally came in may have the number on it.
You can also download a small program and it will tell you your product key number.
Go to the following webpage to download your FREE key finder.
http://www.magicaljellybean.com/keyfinder/
B...You will now insert the disc into the CD/DVD player
C...Restart the computer
D...When the window opens that tells you to press "Any" key, you will press any key you want to press.
E...If you do not receive a message that says "press any key to boot from CD", then then the computer is not ready to boot from a cd.
To correct this problem you will have to go into your computer's Bios and change the computer to boot from a CD.
To get into the Bios, shut the computer off,restart, while the computer is starting up keep tapping F1 as the computer is starting up.
When you are in the Bios, select to boot by CD by moving the cursor with the direction arrows on the keyboard.
Once you have selected to boot by cd the exit and restart the computer...the disc is already in the cd/dvd player.
Your system will then boot from the cd.
F...After a minute or less it should ask you if you want to Quit Repair, or Continue.
You will select Repair this time, but you may have to come back here and select Install if the repair does not work.
It will ok the agreement document if it asks you too.
Tap F8 on your keyboard to pass it when ready.
It will ask you if you want to Install, Repair, Delete Partition, or Quit.
Select Repair
Inside the box there will be one or two partitions.
Choose the largest partition.
After you have chosen the largest partition, you will then press the "r" key to start the repair
After the repair is complete, then you will need to restart your computer.
G...Computer Restart
After the repair is complete, shut the computer down (the computer will shut down a few times during the installation of the operating system
that is normal).
Then restart your computer, when the computer restarts it will have a box to put your product key...put the product key in the box and click.
The computer should start up and run as if it was a new computer.
You do not need to re-register
You can now remove the disc.
If this fails to clear your problem then you may have a hardware problem.
It could be faulty ram
If you still have the same problem, then you have two choices.
1.Reinstall the entire Operating System and you may have to update some drivers.
This will require you to go back to the start of the repair info and select Install instead of Repair.
2..Take your machine in to have the hardware tested.
Keep in mind that if you do a complete reinstall of the Operating System you will lose all the information on the computer,such as pictures, programs, videos, everything you installed will be gone.
Please take time to rate me four thumbs up
Posted on Sep 13, 2011
Testimonial: "Thank you for all the information and step by step instructions! Very helpful !"
Hi! my dDell Optiplex GX520 Desktop does not turn on,all fan working but there is yellow color and nothing to display.help me please!
Posted on Sep 12, 2012
  • Curtis Sewell
    Curtis Sewell Sep 20, 2012
    Check your power supply, it sounds as if it is faulty
Dell gx 520 long beeps and unable boot display?
Posted on Dec 26, 2011
SOURCE:
Why does my desktop DELL Optiplex 1700L just flash YELLOW and refuse to come on, motherboard light is on
An Amber (Yellow) blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 01, 2014 | Dell Optiplex 755 Desktop Desktop Computer...
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid green light means the computer is operating normally.
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Dell loud fan noise
Is the computer completing post? This is indicated normally by a single beep after the power button is turned on. On most computers the beep is proceeded by a post screen with the manufactures logo. If the computer is not getting this far, unplug everything but the memory and video. This should cause the computer to give a no hard drive or OS error. If not pull all the memory, this should cause the computer to give a series of beeps (because there is no memory installed). If this does not work either, you could have a bad mother board or power supply.
Hope this helps
Jan 26, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Dell optiplex sx270: loud, steady noise like an alarm a few seconds after I turn on the PC
You can check the meanings of the error beep codes HERE. Every beep code means something different. The bad thing is that the code I think you are speaking of is a fatal error.
Good luck
Aug 26, 2010 | Dell Computer Refurbished OPTIPLEX SX270...
System unit led is yellow and start good condiotion but no signal
The light on the LCD screen stays yellow?
I would start with puling out the ram chips and see if it works,
If you get some beeps and video works with ram chips out, then its a bad ram chip.
If thats not it.. unplug all cards cd/dvd rom and harddrive to test motherboard and CPU chip. see if you can get video to work with everthing but cpu and power suppy unpuged
Apr 28, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
When i go turn on my dell optiplex gx520 all I get is a flashing yellow light instead of a steady green light. I have checked power supply and reseated all devises with no luck.
checked replacing ram and the motherboard that should fix ur problem or else try booting ur system without modem card plugged it and also by pass surge protector .
Oct 29, 2009 | Dell OptiPlex GX520 PC Desktop
Dell Optiplex 755 does not boot. The steady yellow light on the power switch comes ON but no other error codes on front panel. Machine powers up for few seconds with Yellow light and powers down then wait...
I work at a college and had this same error with a nice few of the Optiplex 755's. However it was due to the power supply failing, nothing with the mother board. Have you tried replacing the power supply?
Oct 15, 2009 | Dell Optiplex 755 Energy Smart Minitower ...
Dell OptiPlex GX520 PC Desktop Logo
1,748 people viewed this question
Clive
Clive
Alun Cox
