Question about Acer AL1916W 19" LCD Monitor
1440 x 900 setting for monitor means I can't see my whole desktop on my toshiba laptop...
I've been using my al1916w as a second monitor for my laptop without any issues.... Just switched From a Dell Inspiron to a Toshiba A100 and cannot get the monitor set up properly.
When I get full use of the monitor (1440 x 900), I am unable to view the entire desktop on my laptop (al1917w is wider than both the Dell & Toshiba screens, but It wasn't a problem with the Dell).
When I can see the entire desktop on my laptop, the image on the LCD is noticably stretched and there is a roughly 1.3inch black strip on bioth the top and bottom of the screen.
I know there is probably a VERY simple solution for this.... Please advise ;)
  • Anonymous Oct 15, 2008
    My desktop view is wide than normal, pls assist me
  • Anonymous Feb 16, 2009
    19"LCD MONITOR EVEN AFTER SCREEN RESOLUTION IS DONE MONITOR SCREEN IS COMING VERY SMSLL? IT IS OKAY WITH 800 RESOLUTION BUT DISPLAY VERY BIG ICONS WHEN I SET TO 1024 RESOLUTION IT DOESNOT COME?
    Novelist:
  • 159 Answers
Not all laptops display adapters will allow the individual settings for a screen and a monitor to take effect correctly.
This happens especially when one is a widescreen and the other is a standard screen.
It seems your settings are taking effect on both screens at once instead of on each screen individually.
I assume you have adjusted te display sizes in your display settings ?
If so, did you adjust each display separately ?
You may also have to see if your display adapter has the most correct drivers. That may help.
Fran
Posted on Oct 19, 2008
All Acer Laptops Compatible wih all Acer LCD Monitors ? Is there any thing specific to look into when an LCD Monitor has to be Purchased to be connected to an USB Port of an Acer Laptop?
You can hook up any brand of monitor to your Acer laptop.
The only thing you may have to check for is that the connector on the back of the Acer (and all laptops for that matter) is a VGA type. This is the older style of monitor connector. Some new monitors come with a HDMI connector. All you need to do is buy an adaper, put that on the end of the cable and plug it in.
When you get the monitor plugged into the laptop and powered up then you will need to go into you display setting and check to see the external monitor is detected and how you want to use it. You can extend your desktop ie make you screen size cover or use both monitors. You can also set it to put your desktop out to the monitor and perhaps one or two other options depending on your laptop model. Once you have it setup it should use those setting automatically the next time you plug a monitor in.
May 02, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
Background color is a light purple
Hi friend,
You need to click "Right Button" on your desktop then click on "Properties" then click on "Desktop" then you can select any image on you desktop.....second thing ....if you want to change your appearance setting ..you need to click on "Appearance" you can select any option which one you want....
Dec 20, 2009 | Acer AL1916W 19" LCD Monitor
Blurred monitor
two things come to mind, locate the newest video drivers from toshiba download them and install.
second you may try increasing your refresh rate on your monitor. Right click in a neutral area of you desktop->Properties->SETTINGS TAB->ADVANCED->MONITOR TAB->MONITOR SETTINGS-at the drop down arrow increase the settings from 60HERTz to 70HERTz
This just might be the ticket to clear things up.
good fortune
Apr 21, 2009 | Computers & Internet
Acer AL1916W pluged into lap top but can't get both to run.
Have you used the Fn button on your laptop and changed the video display Icon on the Blue Function keys. You need to change the display wait a few seconds for it to take affect. There are several modes try them all so you know how to use them.
Mar 20, 2009 | Acer AL1916W 19" LCD Monitor
My screen is bigger than the monitor for my toshiba satellite laptop.
Hi.
What is happening is the settings that you have set on your laptop are too high for the monitor to recognize.
You will need to reduce the resolution settings in you display properties which can be found by going to start-settings-control panel- display- and in the display area choose settings.
Some video cards will let you adjust each item. Some you have to use the same resolution on both screens.
Shout if you need furthur input !
Fran
Oct 19, 2008 | Acer AL1916W 19" LCD Monitor
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
No Signal
Probably the settings on the computer graphics card output.
You need to selct the external screen.
Just to be sure it's not a screen fault, are you able to test it on another PC (desktop, not laptop)?
Jan 05, 2008 | Acer AL1916W 19" LCD Monitor
Acer monitor
What do you mean by it takes awhile to come on? Sometimes with these monitors depending on the type you have it takes time for the PC to pick up the signal. I have my PC hooked up to a KVM switch and it takes about 10 to 20 seconds for my monitors signal to be recognized.
Nov 15, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
154 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
