Question about Kitchen Ranges
I am checking to see if you are still in business. I have many Ultex cookware items. Some need replacing for scatching and broken handles. Most have the 50-75 year warranty from HSN. Please tell me how to handle the warranties. It is no longer being sold on HSN. thank You, Cyndy Patton cynpatton@cox.net
SOURCE: pan Handle
Try this site: https://www.regalware.com/default.pgm
Hope it helps.
Posted on Nov 20, 2007
  • 14 Answers
SOURCE: door handle fell off
Does your range have an all-plastic handle, a plastic handle with threaded brass inserts or a metal handle?
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
SOURCE: main door handle
what's the serial numbber of the machine??that will determine the series you will need, you say oyou hav a series 11 so im assuming your seial starts with 11*********, in which case use the series 10 handle, series refers to a revision in design, next revision shows up at serial 13**********.
Posted on Mar 02, 2008
SOURCE: Whispertone powerhead handle release replacement
Take a butter knife and/or flat head screwdriver and press forward on the four tabs that retain the pedal.
Posted on Jun 02, 2008
hemantraj
  • 638 Answers
SOURCE: Door Replacement
www.applianceaid.com
and
http://www.partselect.com/dishwasher+cup-wont-open+repair.htm
and
www.repairclinic.com
the above links will help u get detailed diagrams n step by step instructions to replace ur door and handle successfully n also clear out any doubts u hve in future regarding ur appliances.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jul 01, 2008
I asked a question about getting new handles for my arcosteel saucepans and got referred to the Cars and trucks secrtion!!!
Arcosteel is pretty much lower end Stainless Steel cookware and unfortunately you will not be able to buy NEW parts for them as is also the case with most of the expensive brands. If any of your items are unusable because of the handle condition you will need to buy a new saucepan.
You might find people trying to sell off used sets cheaply in good condition and you could use the handles off those or the complete unit.
Dec 04, 2015 | Cars & Trucks
How to have lrge skillet (1970) handle re-attached?
Replacement of the skillet could be a better choice.
Sep 07, 2014 | Kitchen Appliances - Others
Handles sears superweight 2 - where to get replacement handles?
J'ai besoin de deux (2) poign?es de remplacement pour une casserole (7") Superweight II achet?e en 1980.
Dec 03, 2013 | Home
Where can I buy a 12 piece stainless steel cookware set?
If money is no issue RenaWare has a lifetime guarantee on their waterless cookware and it is super stuff! Their customer service in replacing is incredible.
Jan 14, 2013 | Home
Where can I buy replacement handles for Amway Queen cookware?
Hi Maggie...
You can purchase replacement handles on amazon/ebay/aliepres etc... but personally I prefer amazon (fast and secure shipping, with affordable prices). So click here Amazon com cookware handles and pick one (which fits to your Amway Queen cookware). Anyway before order, contact the seller to be sure.
I hope it was helpful
enjoy
Dec 22, 2010 | Microwave Ovens
The handle on the door has broken at the bottom. It looks like an easy fix if I can just figure out how to get it apart without breaking it further.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door. If the model number you have this listed under is correct, I found a replacement door handle at repairclinic.com for about $25. Look for item #1381096.
Sep 25, 2009 | Frigidaire FMV157GM Microwave Oven
I have a set of presto pride waterless cookware purchased in 1963
Call 1-800-832-5932 handles 5.95 Regalware Co. Handles Presto Pride parts
Sep 09, 2009 | Presto 06821 Electric Skillet
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
