Question about Frigidaire Refrigerators
What are the normal settings for summer and winter, which is coolest 1 or 7
    President:
  • 1,952 Answers
Cold is better
Posted on Sep 15, 2008
I can't get up a snowy hill with this car - have tried to turn off the VSC and Electronic Skid control as instructed in the manual.
first we have to know what make, model and year the car is. is it a 4x4 or all wheel drive
comment with the details
Jan 25, 2016 | 2009 Pontiac Vibe 2.4L
My refrigerator model tbx22rg works great at winter but at summer doesn't work at all, Why?
Its not even a refrigerator you dumb egyptian ****.. SOME ONE SOLD YOU A REFIGERATOR BOX~!!!
Aug 04, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
I just had a representative from the Geek Squad set up my Epson WorkForce 633 Fax/Printer/Copier. The time that we set up is not what I wanted. I want a 12 hour set up, and I need to reset the clock on...
Below you will find the instructions straight out of the manual. I have also put a link to the whole searchable HTML manual at the bottom of this post Enter the Date and Time Before setting the date and time, you should select the appropriate Daylight Saving Time setting for your region. This setting lets you easily set the clock one hour ahead or one hour back when the time change takes place. 1. Press the fax.6.7.1.jpg Setup button. 2. Select Printer Setup. You see this screen: fax.6.7.2.jpg 3. Select Daylight Saving Time. 4. Select Summer if your region uses Daylight Saving Time and it's currently in effect. (DST is effective from spring through summer.) Otherwise select Winter to turn off the setting. Note:
When you change the setting from Winter to Summer, the clock is automatically set ahead by one hour. When you change it from Summer to Winter, the clock is set back. The setting is not automatic; you need to change it each season. 5. Select Date/Time. You see this screen: fax.6.7.3.jpg 6. Select the date format. You see this screen: fax.6.7.4.jpg 7. Use the numeric keypad to change the date, then press OK. fax.6.7.5.jpg 8. Select the time format. fax.6.7.6.jpg 9. Use the numeric keypad to change the time, then press OK. 10. Press fax.6.7.7.jpg Back until you return to the home screen. Epson Work Force 633 Manual Hope this helps. Zeppelinx12
Mar 10, 2011 | Office Equipment & Supplies
I have a fridge/bottom freezer fridge and i would like to know at what temprature i should set my fridge. Its a manual setting ranging from 1 to 7. which is the coolest setting?
#1 is warmest going colder as you go upto #7.fridges should be set at +3C,adjusting the control for summer and winter.you could do the lettuce test,if it goes soggy/black,its too cold.
Jan 25, 2011 | Whirlpool Refrigerators
Just wanna know how to set the temperature on it
dehumidifiers do not have a temperature control, rather, they have a humidity control. usually you set the humidity control to go off when the level of moisture in the room reaches normal (approx. 25-35% winter;38-55% summer). Best way is to run it at full on for 1 to 4 days (until you know the moisture level is how you want it), then turn the knob until the unit goes off . This will be the ideal setting. Goodluck<Macgivor
Jan 16, 2010 | DeLonghi DDE40E Dehumidifier
What fuel is best for my Chev Malibu, 2003. I live
Standard 87 octane is all that car requires. You will gain no benefit from using mid or top grade fuel.
Most passenger car tires are run between 32 and 35 psi, regardless of season. You can look at the side of the tire to find what the max cold psi pressure is. You will normally find that it is 35psi.
As for summer/winter tires. If the wobble only happens when the snow tires are installed, and not with the summer tires, that obviously eliminates the car as being the problem. Do you have your summer and winter tires mounted on different sets of wheels, or do you swap the tires every season on the same wheels?
If they are on different sets of wheels, then the winter tires are out of balance, have some sort of damage to the carcass of the tires, or you have a bent wheel. If you are using the same wheels and swapping the tires every season, then you need to have your winter tires balanced and see if it solves the problem.
Dec 18, 2009 | 2003 Chevrolet Malibu
In the winter, my car makes a sound like a piston Knock. i have been told that my car does not have pistons. is this true? in the summer it does not make that sound even if driving on a cold engine, in the...
Yes your car does have Pistons.. and No its not normal for this to happen in the winter. However I would recommend that you use a lighter oil in the winter than the summer like 5w-30 or 10w-30 no higher. Good Luck
Jan 02, 2009 | 2003 Mitsubishi Eclipse Spyder
Gorenje KE267MLA Fridge too warm
higher the number, colder the fridge ie 7 is the coldest setting
switch with red dot is for summer/winter operation. only necessary to switch it on if the appliance is in a cold location
Sep 30, 2008 | Gorenje Refrigerators
Refrigerators Logo
70 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
