Question about LG VX8550 Cellular Phone
Slide up part is broken
It doesnt slide up all the way and doesnt close all the way
something that keeps it up inside broke and im not sure if i can fix it on my own and what i should do
    Champion:
  • 221 Answers
I would buy a new one. things like that aren't very easy for the end use to fix
Posted on Nov 11, 2008
Hey , I have a 1997 t-bird and I need help getting a name for a part , I don't know how to fully describe it , but a part to my door latch broke , and it's keep the door from closing all the way , the only...
It's called the door latch. You can't buy parts for it. You can buy the whole mechanism though. Or get one at a junkyard. A spring or small pin has broken inside of it. I tried to many times to find parts for the inside of these things. No luck.
Nov 03, 2014 | Cars & Trucks
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
My sram x-7 derailleur hanger broke and i bent the derailleur. I've replaced the hanger and re alligned the derailleur but i went to bolt the derailleur back onto the hanger but the bolt doesnt seem to be...
You need to replace the main pivot bolt, something (most likely a tab) is broken. This one is best taken to your local bike shop for inspection. There may be something your missing like a crack in the body or another broken part. Link to Manual.
You can also contact the SRAM customer service for support, but they will refer you to a shop to take care of the problem and order any parts on this type of problem.
Dec 14, 2010 | Sram X7 Mountain Bike Rear Derailleur
Dash and tail lights fuse keeps going bad
if the fuse continues to go bad, take your tail lights out one at a time and look at them closely to make sure a filament isnt broke, and connecting with the other, also check the sockets the lights go in.. im pretty sure you will find something with the rear lights..
Dec 08, 2010 | 2000 Dodge Durango
Hello I have a LG Microwave/grill/convention oven. I caught my bracelet on the bottom lug thing that is attached to the door and now the microwave runs all the time? Please help is this something i can...
Sounds like part of the peg broke off and is left inside the recepter slot area where the sensor switch is. If it is the lower door plastic hook thing (inside bottom) that broke off, it is possible to re-attatch it to the door if you save the broken piece. Drill a small hole the size of a small wire or nail you have lying around to make a splint - Cut the nail or wire to about 1/2" to use it as a hidden "bone" or skeletal support inside the broken plastic. Glue the nail half way into the broken plastic using modelers glue. Closely align the nail peg to where the plastic broke off and mark it for drilling. Drill carefully making sure you are centered so that your wire "bone" will allow proper alignment of your plastic. Insert the pinned piece into the newly drilled hole checking for alignment, if it looks close enough you can glue it in place and you should have a strong enough repair. Dangerous to use a wooden peg to fool the internal switch. As it will be running even when the door is open and you don't want to get zapped.
Nov 04, 2010 | Microwave Ovens
Color LaserJet 3800 series - Error message reads
You have a problem with the slot that the yellow cartridge slides into.
Pull out all the cartridges and reseat them. Power cycle the printer. If the 10.92.03 is still there, then something is broken inside. Pull the cartridges and look inside on the right side. Compare that area for the yellow toner to the other colors. Look for a steel wire that is out of place at the yellow position on the inside right frame. The part is a cartridge lock. If it's broken, you will need a tech to replace all the locks at the same time.
Even if it's not a broken yellow cartridge lock, something else is physically broke and you will still need a tech.
Due to the age of the printer, i'm guessing that you don't have a warranty.
Jul 22, 2010 | HP LaserJet P3005D Monochrome Laser 35...
Turn Signal replacement /Ac query
you can either take the colum assembly off and remove the 2 screws and wires holding it in place and it should come right out, new one from junk yard or a parts store will work fine
Jul 04, 2009 | 1987 Cadillac DeVille
My samsung gravity slider is bust
It sounds like the tracks have slipped. Unfortunately, there isn't anything that can be done at home. You need to take it to the retailer.
Jun 04, 2009 | LG RUMOR Cellular Phone
New Slider Does Not Work - key lock too!
I Would send the phone back, you could be damaging it even more.
Sep 21, 2008 | Samsung SGH-D600 Cellular Phone
My phone slides up but something broke and now it doesnt close properly and slide up all the way
Emina that means something really is broken, and that you need to take your phone to a technician for him to fix it.
Sep 15, 2008 | Lands Phones
LG VX8550 Cellular Phone Logo
106 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
