Question about Compaq Computers & Internet
I have a friend with a Compaq Evo N60c laptop. He has asked me to see if i can get it working as there seems to be no life in it. It's plugged in but the battery has been fully discharged and even plugged in it takes NO power and is totally lifeless?? I have checked all the conections and all seems to be ok and there is power from the mains lead. (though not sure if there is enough power i'll have that checked today) Can anyone help move us on a little further with this or is this a common thing with Compaq?? Does it need fixing with a new one? Thanks in advance for any help. Rab.
  • 1 more comment
  • rabtmac Sep 15, 2008
    Thanks for the answers and yes it is the Compaq EVO N600C
    I've now had the power supply checked and its perfect putting out 18.72v so its fine
    I tried what was suggested except removing the CMOS battery as i don't know where abouts it is in the mashine.
    Also i ment to ask earlier is there a small fuse in the mashine at all??
    I get no light and it's as if the power just isn't getting into it????
    Think i've just found the CMOS battery under the panel with the start button on it.
    Would this battery being dead cause the notebook to not show any sings of life??
    Not even a single neon light or even a glimmer of one??
  • rabtmac Sep 18, 2008
    Hi all,
    I just purchased a CMOS battery and installed it but still the same problem???
    No life in it at all.
    Do i need to put the battery in and leave it for a while or try to charege in ivertime.
    Thanks
    Rabtmac
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
This often happens with notebook batteries - even unused, there is a limited shelf life. (I had a brand new one that, after sitting ready as a "spare" only, would not work after some 3 - 4 years.) As there appears to be no N60c notebook, it is assumed that you are referring to a 600, 610, of 620.
The primary issue you are having in booting up is, with a very high level of probability, the CMOS battery. Life on these internal batteries varies - some have been known to go in 5 years or less, and others are still active more than 15 years later. At any rate, experienced this directly - 2 machines that had sat unused for some 2 years, and when powered up, nothing. Both could not reasonably have been expected to "just die" at the same time. Turned out that replacement of CMOS battery solved all problems (for just a couple dollars each).
Finally, quick word of caution. The battery for the unit that has completely discharged should be removed. You may either replace it or use the battery compartment cover that should have been with the notebook, and utilize only the A/C adaptor. The reason for this is so that you can isolate the cause of the failure to boot. A laptop battery that has fully discharged could be a constant source of frustration and irritation to a notebook, causing numerous issues, including rebooting at will.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 15, 2008
  • 2 more comments
  • Cheryl Whalen Sep 15, 2008
    Yes, CMOS battery being dead will cause it to seem ENTIRELY dead.
    Do you need help locating the battery?
    Hi there. Did a little more searching for you, so you could actually see the placement of the CMOS battery within the machine. Go to http://bizsupport.austin.hp.com/bc/docs/..., section 5.6, which is titled "Disk Cell RTC Battery". There are good, strong (understandable) graphics in this manual, regarding the interior parts of the notebook.
    I also found a brief article regarding the RTC (Real Time Clock) battery - otherwise known as CMOS battery - that explains the reason the PC doesn't boot. Basically, this is not an issue in many newer models, as when I experienced the issue I had previously, I discovered that most now are rechargeable CMOS batteries, and can last theoretically "forever". However, that is not our case. Our batteries are the "older" type that store basic BIOS info within the RAM of the RTC, which keeps the machine from booting up. Hope this helps you to gain a little more understanding as to why the system does what it does until the battery is replaced. http://computer.howstuffworks.com/questi... (Once mine were replaced, both booted up without a hitch!)
  • Cheryl Whalen Sep 19, 2008
    When you were inside the machine, to replace the RTC battery, did you verify that no other parts or cables appeared to be loose or damaged? Additionally, did you have a chance to review the manual for which I posted the link? Please verify that the proper battery was placed (CR1220 lithium disk) with the positive side up, without difficulty. If there were no other obvious items inside the machine, and everything reassembled without issue, then we should try a couple more areas.
    The PC should be powered solely through the AC adapter to test that piece. Remove any docking station or battery packs. Then, making sure that you are using a functional electrical outlet, plug the AC adapter into the PC, and then into the outlet. This should produce a light which indicates that power is flowing through the AC adapter. If not, then either the adapter itself or the power cable may be bad. Replacement part numbers can be located in the manual, or you may obtain replacements (which can be returned if they do not solve the problem) at many retail or online locations. If power is brought into the PC, then there are a number of updates to be applied to the PC, and it is not possible for me to know which have been applied and which have not. However, if you can get power to the machine, many of these updates are critical to the ongoing functioning of the machine. Certain also relate to the battery and/or the docking station. In addition, if the machine is to be retained and used as a portable, a new battery pack is likely necessary, as it is well past the typical life of the standard battery pack.
    If the adaptor &/or replacement testing does not work, there could be issues with the connector(s), the CMOS battery placed in the PC could be bad, or there could be several other items which we can test. If you would like to continue to pursue this, please let me know, and we will move forward. Please be aware, however, that if the end result is that a component-level repair is necessary, an authorized HP tech will be required to perform the repair. Please let me know how you would like to move forward, and I will be happy to help you. (There are a number of other items on the potential list of items that could be creating the problem, but I did not want to overwhelm you with too many at one time!)
  • 535 Answers
U have to change the charger soket from the laptop its has been dry solder
I have compaq evo N610c laptop, it works when plug power cable. battery also charging. but when i remove power cable computer shut down
Hi this may be due to your laptop battery problem. It may the time now to replace the battery of your laptop as it may go week now with time.
So very simple just go to any compaq service center and ask them for a new battery.
Nov 24, 2010 | Compaq Computers & Internet
Recomened VGA Driver for Compaq Evo n600c Notebook PC
Hi friend,
You need to open www.compaq.com then you need to select your model no.. then you can download. your VGA Driver for your compaq....
Dec 26, 2009 | Compaq Evo N600c Notebook
I have a sony evo n600c and when it starts up its says 103 charge circuit fails does and the battary does not work i know i will need another battery but what i am asking is is the 103 charge circuit fails...
This error is commonly seen in Compaq laptops. Take out the battery,start the laptop with the adapter only and see if that error message pops up again and if not then it might be your battery.Usually battery life is 3yrs. Put the battery back again and see if the message pops up again. Try the battery on a different laptop. It could be the Voltage Converter Board...see service manual for the same or call Compaq service centre.
Jul 28, 2009 | Compaq Evo N600c Notebook
No sound from my evo n610c from compaq
It is a known fault with the speakers - obtain a replacement set but be aware though the panel is easy to lift the plugging in of the cables into the m/board requires some dexterity.part number from hp,
241438-001 Switch cover - Plastic panel above keyboard that houses the LEDs, power switch, and Internet buttons plus speakers
Mar 10, 2009 | Compaq Evo N610C Notebook
WIRELESS ADAPTER
To install your wireless adapter, plug in the wireless card, and put your cd driver into the laptop. Once the adapter is plugged in, your laptop should recognize a new hardware has been installed, and will ask you for a driver (whether to automatically search for it or you can install it yourself. Pick the option of you installing yourself, and put the cd driver in. Then just go through the wizard to install your wireless card. You should be good to go from there! Any other questions, let me know!
Nov 21, 2008 | HP Compaq Evo n610c Notebook
How to reset BIOS password for Compaq EVO N160 notebook
Do the following steps -
- Remove the laptop battery - Remove the CMOS battery - Leave it for idle for around 15 minutes - Put the CMOS battery in - Boot the laptop  with AC power - Then put the laptop battery in.
 - The BIOS pwd would have been reset now
- For troubleshotting the battery - Go into BIOS and run the Battery Caliberation tool
Hope this helps. Thanks, AK
Oct 27, 2008 | Compaq Evo N610C Notebook
Multiport w200 wireless goes to blue_screen with belkin G+ router
http://www.fixya.com/support/t612983-blue_screen_hp_wlan_multiport_w200 seems to have the solution.
It says:
Rollback the W200 driver to version 1.00C. Subsequent drivers are incompatible with XP SP2.
Unfortunately, WPA support came in version 1.00E, so W200 + XpSp2 = no WPA support. :(
I removed my wirelss drivers and compaq wireless client software, then installed the older driver from http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=hb-13082-1&lc=en&cc=fr&dlc=en&os=228&product=235687&lang=en which is sp23031. This seems to have worked. s.gif
Oct 07, 2008 | Compaq Evo N610C Notebook
Compaq evo n610 screen dead
all you need do is to change the LCD (screen) and the module.
module is closse to the screen, under the monitor.
Jun 13, 2008 | Compaq Evo N610C Notebook
Evo n400c
Did you charge it for up to 8 hours?
Caring for your Compaq Evo N400c Laptop Battery You can improve the life of your Compaq Evo N400c Laptop Battery by doing the following:
When you first receive your laptop battery charge it fully for at least 6-8 hours and then discharge the battery fully by using your laptop unplugged from the mains until it runs down completely.
Repeat this 3 times to ensure your Compaq Evo N400c Laptop Battery will give you the maximum performance.
If you regularly use your Compaq Evo N400c Laptop on mains power for extended periods, removing the battery from your Laptop during these periods will extend the usable life of your laptop battery.
Apr 05, 2008 | Compaq Evo N400C Notebook
Computers & Internet Logo
100 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
