Question about LG DU-42LZ30 42 in. LCD HDTV
No picture or sound
I went to turn my tv on a couple days ago, and it has no picture or sound. was perfectly fine the night before. Wehn I push the power button it make a brief clicking noise and the power light blinks for a few seconds then my screen is just black. Was it wrong or what could have caused this. And is there anything I can do to fix it?
Thank You!
  • LG Master
  • 5,568 Answers
The symptom you describe points to a failed main power supply, unfortunately pretty common. There may be an internal fuse you can replace but I wouldn't bother doing that more than once.
The clicking you hear is a relay that repeatedly connects, then disconnects the AC to prevent fire or further damage.
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Nov 23, 2008
Was working fine last night ,went to turn it on and you can hear a buzzing by where you plug in your jacks a bee,or high pitch sound.tv has no picture or sound.only sound you hear is this buzzing
Sounds like your power supply is causing the problem. Unplug the TV wait 10 minutes, look in the back for a red button (circuit breaker) push it in. If this does not work you have a low voltage power supply fault.
Mar 04, 2016 | Televison & Video
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv not powering on
as per your statement there is a loose contact in power supply section of your tv. it is 1oo% sure that allthe parts are ok as tv runs ok when it comes on. but you will have to call tech. as without knowing technology it is dangerous to open tv due to high voltage.
Sep 15, 2007 | RCA HD52W58 52" TV
Won't Turn On
I bought a proscan tv about a months ago. yesterday it stopped working. The red button is on which shows that it is receiving power however, there is no picture nor sound.
Aug 27, 2007 | Proscan 19LA25Q 19 in. LCD Television
LG DU-42LZ30 42 in. LCD HDTV Logo
141 people viewed this question
Computer Repairing
Computer Repairing
